No power and a flutter sound
I been having a flutter sound for about 2 months now it comes and goes randomly. When it is present i cant boost but 2-5 lbs. I ended up getting a CEL with code P2261 bypass valve stuck. So i got a forge bpv and the im still having the same problem, I've tried both the yellow and green springs didnt make a difference. The other day i was backing out of my driveway and it was acting like it wanted to stall. It smoothed out and I continued to go down my road. I then noticed the flutter sound came back once again along with a CEL so i had it scanned and i now have 4 different codes.. P2187 fuel trim lean, P0234 turbo engine overboost, P0236 boost system performance and P2261 bypass valve stuck. Iv checked the vacuum tank its fine. Anybody have any suggestions? Thinking about changing the bypass solenoid next but idk if that will help. Thanks in advance
its most likely the solenoid, just bypass the solenoid for a run, connect ur bpv line straight to manifold, then plug ur vac tank into the solenoid where bpv was to close the port so u don't have boost leak. u should know in a few minutes if that's ur issue or not. if it works fine, change solenoid.
Sounds like your solenoid. Mine did something similar. My forge started to open during normal driving(-5hg though zero). Then I put the stock one on and would always hear a loud whistle from the turbo, and no BPV sound when letting off the gas in vacuum.
Replaced the BPV solenoid and no more whistle with stock BPV. Put the Forge back on and its no longer opening or sticking open during DD. |
I put a new soleniod on and the flutter has seemed to go away but before i had any problems when under full boost and letting off i would hear a very define sound of air now it just sounds as quite as it was with the stock intake.
Originally Posted by turbochargedss2012
(Post 7568531)
Anyone know what the solenoid part # is and where to buy? Thx
Ebay item number 111575766855 sold by zzp
Make sure vac lines are on tight. Had this problem
Question
Hi I recently bought a colbolt ss turbocharged with a tune and turbo everything done to it but the bov you don’t hear I don’t think even at all or barely what might be the cause to that? Or should I get a new bov that it might help or what might be the issue that I can’t hear the bov ?
Originally Posted by Adrian Vest Jr.
(Post 7732005)
(Post 7732005)
Has anyone tried using this adapter I found on ebay?
https://www.ebay.com/itm/114185463004https://cimg1.ibsrv.net/gimg/www.cob...319a44f995.png |
| All times are GMT -4. The time now is 01:26 AM. |
