NOS on an 08 ss/tc??
Old Sep 11, 2008 | 10:46 PM
krispy's Avatar
no idea
Old Sep 11, 2008 | 11:03 PM
jwhitten's Avatar
Well i'm gonna go ahead and get the kit I'm sure I can figure it out just gotta do some research
Old Sep 12, 2008 | 01:30 AM
choko's Avatar
I run 12's on nitrous with stock turbo. 8000 feet up.
but had my 3rd cyl explode last night at the track ' ring failed'.. so im in process of doing new motor build and bigger turbo,. and still will do nitrous. prolly a 75 shot. just to help turbo spool cause im gonna go a decent size.
the Lnf LOVES the bottle. i sprayed every car i owned. even snowmobiles. and a 50 shot on a stock boosted lnf runs like a raped ape. but dont over boost a stock turbo and spray alot or you will have failure
Old Sep 12, 2008 | 01:38 AM
hungryhip-ccp's Avatar
it dosent have to be 43 psi... the lsj is almost 65 psi...
Old Sep 12, 2008 | 01:54 AM
choko's Avatar
Originally Posted by enemy no1
I laughed when I just read this and everyone is repeating saying "choko" "choko" "choko" "choko" because I always had a very strong feeling that his n2o setup wasnt safe even though he claimed it was. I even called him out on it in his 4 page thread or whatever it was and whadya know....he blew it up. lol I'm not suprised one bit if its true.
when you run alot of boost and alot of nitrous. no matter how perfect your tune is. when you have alot of cyl press. ***** gonna happen. push stuff till it blows then build better. like always. also im a nitrous *****. i use nitrous like its going out of style ' ill spray anything just since i have it, huffy bikes, mini vans, rascle scooters, ya name it hahah. other forum mods always give me a title like: nitrous ***** lol
Called me out? im not gonna brag, but i do make very good $. so if you really want to call me out. make a call out thread and put up $. my car will be done in 2 weeks once i get some more time to fix it. you can run my hummer h2 if i dont run ya over
jk
Old Sep 12, 2008 | 12:35 PM
ralliartist's Avatar
Originally Posted by FiscalFizz
Everytime someone says NOS instead of Nitrous, there is always a Douchebag there to correct them
YOU JUST GOT PWNED RALLIARTIST!!! HOW DOES IT FEEL HOW DOES IT TASTE !!!!
so you think I'm a douchebag and I got pwned? okay, what have you contributed to the forums?
I'm not even offended. I'm laughing.
Originally Posted by Bluebaltsc
what are you 60 years old? either grow up an die or adapt to what the majority calls it
i think choko pulled a 13.3 or something before he blew up still waiting for the vid
what? what the majority calls it? No, that's what ricers call it. It's nitrous. Maybe the "majority" that you hang out with needs to grow up. Most people I know call it nitrous, the clueless people I know that still rice cars out call it NOS.
Choko blew up??? When did that happen?
Originally Posted by RBC
Why would you say something like that? I don't think it is the majority because 99% of the people that I run into that call it NOS are total tools, not saying you are but that is my experience. Most knowledgeable car guys call it nitrous, the only thing that needs to die is that term(NOS), unless you are referring to nitrous oxide systems. Enough about that I dont want to turn this thread into a debate.
thank you very much. Point proven.
Last edited by ralliartist; Sep 12, 2008 at 12:35 PM. Reason: Automerged Doublepost
Old Sep 12, 2008 | 12:37 PM
1BADSS/SC's Avatar
Its actually Nitrous Oxide, to correct everyone here.
so now you run 12's? I know you have the trap speed, but your driver mod needs attention last I heard. So why does this say
SS/TC,MODDED,(NON-STOCK TURBO AND/OR OTHER POWER ADDERS)
1.)choko,13.14@109.19 w/2.22 60',E/DP/N20/ST
and where did you post your 12sec run at?
want to show a slip?
Proof?
Old Sep 12, 2008 | 12:54 PM
krispy's Avatar
You didn't correct me!
https://www.cobaltss.net/forums/show...7&postcount=20
Old Sep 12, 2008 | 01:32 PM
jwhitten's Avatar
allright enough of the freaking N.O.S. **** yes I said NOS I was referring to the blue bottle kit from holley called with the big letters NOS on it. if your not going to help me out then get the freak out of my thread I am asking for help not to be bashed for being a freggin ricer, You call me rice all you want but in the end I its what ever you want to say but if your not going to help and just bash the term NOS then shut your trap and get the **** out. Out of this whole thread I think there are 3 people actually trying to help. Go figure the rest of you have nothing else better to do than try and prove you know something you may or may not but in the end if your not going to help then just keep yout trap shut.
Old Sep 12, 2008 | 01:44 PM
  #36
krispy's Avatar
Ok, I'm blind, I should have realized yesterday when I was looking at the fuel pressure regulator there is a schrader valve on it. That makes things much easier lol.
Old Sep 12, 2008 | 01:58 PM
  #37
jwhitten's Avatar
Thank you for your help I appreciate it now is the regulator the round siver thin on top of then engine where the hard line that goes to the fuel rail comes from? I wonder what the pressure is there?
Old Sep 12, 2008 | 02:03 PM
  #38
krispy's Avatar
When primed it should be 57-67 psi per the document I am reading, so it seems it should be just the same as a normal fuel pump
And actually from what I am reading the regulator is in the tank MRA, the round module on top of the engine is a pulse dampener to smooth out fuel flow before the high pressure pump.
Old Sep 12, 2008 | 02:19 PM
  #39
either way, choko has ran nitrous already and there have been lots of LNF sky and sol's that ran nitrous. If I remember correctly, there was one guy that was able to get up to a 250shot before the motor blew. So from previous experience of other owners and for the simple fact that the direct injection is a whole new ball game, i'd say a 75 shot is perfectly fine.
Last time I checked, I posted that. Is that not helpful information? I told you a guy that has ran nitrous and then I said that LNF sky and sol's have been running it for a while. That should clue you in to check out the sky/sol forums.
I'm done with this thread. Ricer.
Old Sep 12, 2008 | 03:02 PM
  #40
jwhitten's Avatar
You think that would work for the fuel supply on a wet kit?? The kit number is 05130NOS and it reccomends fuel pressures I think 45-50psi I cannot look it up right now because i'm on dial up at home and its taking for ever to load.
I appreciate everyone help pwho is actually trying to help.
Old Sep 12, 2008 | 03:11 PM
  #41
krispy's Avatar
Higher pressure won't hurt, for a given jet setting that is optimal @ 45-50 psi you will be running a little richer when your fuel is 57-67 psi, nitrous will remain the same. I think the right way to tune it though is go with recommended jets, then adjust fuel jet size according to the A/F ratio from the O2 sensor.
Old Sep 12, 2008 | 03:37 PM
  #42
choko's Avatar
Proof?
that was before. and drive mod? my 60's sucked before due to nitrous blowing off tires, fixed that and got radials. 13.1 was on bottle with stock tune/boost 12 sec runs were on tune/more boost/nitrous.
i have a few slips no vids so no reason to post. a black ss/tc seen me run 12's a few times at the track. told him to signup here.
dont see what the deal is again ralli. i ran 13.1's so no big deal to hit 12's with tires,more boost and tune is easy bud.
Old Sep 12, 2008 | 04:55 PM
  #43
PimpLay2's Avatar
choko u dont need to prove ureself u all ready proved every 1 wrong when u posted dynos and then proved the dyno and u all ready proven to be the fastest t/c out there with hahn i believe the 12
Old Sep 12, 2008 | 05:31 PM
  #44
FiscalFizz's Avatar
What different brands of NOS are there? Does NOS make your car go ZOOOOM?!?!?
How much am I looking to pay for NOS?
Does it come with the laptop computer and a cool red button I can push to make it go super-duper fast...the NOS that is.
I want my NOS to be exactly like Paul Walker's car in the Original Fast N Furious movie.... we all know thats the BEST ONE!.
NOS NOS NOS
Old Sep 12, 2008 | 05:44 PM
  #45
he didn't prove anyone wrong. He said he hit like almost 300whp and over 300wtq from just a muffler delete. He forgot to mention the nitrous. LOL.
Either way, I know that your trap speeds are good for 12's Choko, I just don't recall you mentioning 12sec times until just now. If you don't mind, if you want to keep all BS aside, could you pm me your 12 sec slips. I'm just curious.
Old Sep 12, 2008 | 05:45 PM
  #46
1BADSS/SC's Avatar
NOS NOS NOS
QUICK! Get a pacifier for him! He needs something to suck on.
Old Sep 12, 2008 | 05:51 PM
  #47
FiscalFizz "spouts off with **** holster"
That's what it should say under your screen name instead of "Mushroom prints with his"
LOL
Last edited by ralliartist; Sep 12, 2008 at 05:51 PM. Reason: Automerged Doublepost
Old Sep 12, 2008 | 06:06 PM
  #48
1WhiteSSTC's Avatar
For the record I call it spray, i'm just saying, a large majority call it NOS even if it's just a brand, it's not like there isn't all sorts of similar saying in our society with the same generalization, and u don't snap at ppl for them do you?
Old Sep 12, 2008 | 06:22 PM
  #49
_UnLiMiTeD_'s Avatar
my god, a cobalt owner, wants a nitrous setup, the brand of it is named NOS, made by holley, he explained why he called it that, to say the brand and you immature idiots still wont shut up about it. **** sakes, grow the hell up.
Old Sep 12, 2008 | 06:24 PM
  #50
choko's Avatar
i had 12.x in sig for a while . never noticed? lol
when i go to shop ill get some slips out of the car.
**nitrous kits** i always use dyno tune nitrous kits. they are good/made in house and priced well
