not boosting at set psi
Old Mar 24, 2014 | 11:17 PM
dro-balt ss's Avatar
noticed recently i with trifecta off i can only get to like 12 psi but it holds at 12 and trifecta on should be 23 psi it only gets to 20 anyone know the fix?
Old Mar 24, 2014 | 11:25 PM
andrewcarr1993's Avatar
Boost gauge is definitely working?
Old Mar 24, 2014 | 11:29 PM
ya i know what my turbo sounds like when its peaking correctly and deffinately power reduced
Old Mar 25, 2014 | 05:33 PM
Old Mar 27, 2014 | 06:30 PM
Shortbus's Avatar
Check for boost leaks first, check sensors, solenoids, any cel? If you are running that bov with out a tune might not help either...
Old Mar 27, 2014 | 08:19 PM
09CobaltSS1's Avatar
Did you install that bov you were referring to in another thread or are you still on the stock bpv?
Old Mar 27, 2014 | 10:11 PM
this was before i even purchased the nov, it happens sometimes and then other times itl run fine, no cels. i didn't think it was a boost leak because theres no play in the gauge it stays pinned at 12 or 20
Old Mar 27, 2014 | 10:18 PM
Shortbus's Avatar
If there is a leak it will not achieve maximum boost, you need to boost leak test the car.
Old Mar 27, 2014 | 10:45 PM
probably my sri to my turbo inlet i was ****** around with it to get to my motor mount. got my intercooler and charge pipe going in soon so i can live with it if its not the turbo inlet
Old Mar 27, 2014 | 11:44 PM
footballplaya3k's Avatar
Intake side of the turbo doesn't effect boost unless you blocked it which is unlikely.
deviance
Nov 24, 2015 05:51 PM
no_ss
Oct 18, 2015 11:58 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Sep 27, 2015 08:53 PM
