Oil filter question
Oil filter question
Ok so im a ******* and when I was at my buddy danas house changing my oil we were in a rush and completely forgot to change the filter.... yes i know...... anyways. My ? is can I change the filter without draining the oil or? Thanks guys.
Edit: Sorry this is also in the wrong section..... jesus haha.
I would say you should be able too....BUT I would change the oil again because now you have put your clean oil through a dirty filter and your oil will have that in it now. I am not sure how much it will hurt the oil....I am not a professional mechanic. But in my mind I would change the oil again if you change the filter.
The oil is in the pan, which is typically lower than the oil filter location. You will lose some oil, but not all. I would just check the level and add the necessary amount.
You only loose what doesn't drip back off into the caniseter when you pull it out. Completely safe and easy to do, I've also changed filters by themselves without changing the oil.
