oil galley
Old Aug 25, 2011 | 09:26 PM
1971/2009 Chevy's Avatar
oil galley
does anyone have a diagram of how the oil is routed through the block? does it go from the pump to the intake side or the exhaust side or what? , im wondering because, i would like to install an oil temp and pressure gauge and i want to mount the temp as close to the pump and the pressure as far away (before it goes in to the head and the pressure is dropped ) as possible.
Old Aug 26, 2011 | 06:48 PM
tomj77's Avatar
the only place ur gonna get a pressure gauge installed is just under the turbo or i think under the intake. the plugs on the head give u wrong reading cause of the design i believe, but a oil temp guage would work there i believe. just on the driver side of the head there are 3, i think one is being used for the oil light switch.
Old Aug 26, 2011 | 08:34 PM
iboost's Avatar
sub'd
Old Aug 26, 2011 | 09:17 PM
thankyou, yea i have seen where others have mounted the pressure gauge on one of the 6 plugs in the block but i guess im wondering which one is best. if im going to go through the hassle putting it in i want it to be the best spot i dont mind having to run something like this Remote oil pressure sender which i might do anyway but the temp senders are usualy small and im just wondering if any one knows where the BEST spot is...
Old Aug 26, 2011 | 10:13 PM
tomj77's Avatar
the one under the turbo is the easiest to get at, but it is a pita to do, u need some extentions and angled extentions for ur socket to get it done. and u need this
Autometer Electric Temperature or Pressure 1/8" NPT to M12x1.75 Ecotec Oil Feed Adapter - Interior - Turbo Tech Racing, LLC
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
Trav3480
Oct 1, 2015 08:17 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
