Oil Leak...Different Spot
I am going to take pictures in a day or 2 but i Have an oil Leak on the side of the engine. It is in a circular part on the ride side of the Engine. IDK what is is or what this location is called. Im not happy at all.
Also. track times
.8840 reaction
2.51 60ft
14.66 1/4 mile
103.23 mph
im not happy....
Also. track times
.8840 reaction
2.51 60ft
14.66 1/4 mile
103.23 mph
im not happy....
Well that 60' looks like it killed you....your trap speed is on track with a stock SS/TC though. Do you have a tune?
Yesterday I ran following....in comp mode, but didnt use launch control. All stock, just a filter.
60' - 2.232
330' - 6.052
1/8 - 9.107
MPH - 80.26
1000 - 11.711
1/4 - 13.888
MPH - 103.57
Sounds like you must have had some serious traction issues. I definetly had some...I think on a warmer day i can get the 60' down to 2.1...possibly a little lower. Just work on your lauch and traction through the first 1/8th mile and you should be good.
As for the oil leak, the circular thing on the right you are referring to sounds like it is the cap for the oil filter cartridge. Take a wrench and tighten it down to see if it goes away. If not, bring it in to the dealer (I would suggest you bring the car as close to stock as possible when you do that)
60' - 2.232
330' - 6.052
1/8 - 9.107
MPH - 80.26
1000 - 11.711
1/4 - 13.888
MPH - 103.57
Full time slip
2.5150 60 FT
6.5810 330 FT
9.7469 1/8 ET @ 78.13 MPH
14.6639 1/4 ET @ 103.23
and yes i am stock. And as far as the leak i will take a picture of it.
What worries me is. How will i get traction now if i am stock and cant hook up. And when i get all mod mods. Check sig. it will be worst!
2.5150 60 FT
6.5810 330 FT
Full time slip
2.5150 60 FT
6.5810 330 FT
2.5150 60 FT
6.5810 330 FT
Those are prob going to be on the list soon.
I was however impressed with my trap speed...i know i can get into the 13's!
Red. im guessing you had the same prob as me?
Full time slip
2.5150 60 FT
6.5810 330 FT
2.5150 60 FT
6.5810 330 FT
not sure wht ur talking about...
ur filter?
or maybe one of ur galley plugs.
there are tons of circular things ur oil can leak from on the right side of ur engine lol. and please use terms like passenger and drivers side so people can understand.
ur filter?
Also. track times
.8840 reaction
2.51 60ft
14.66 1/4 mile
103.23 mph
im not happy....
Also. track times
.8840 reaction
2.51 60ft
14.66 1/4 mile
103.23 mph
im not happy....
Looking at the engine from the outside On the Drivers side
Looking at the Engine... I believe its the opening where the Valve cover is. or atleast near it. And it is a circular shape there where the oil looks to be leaking out. Its hard to explain with out pictures
uploading a pic now....
Last edited by Mazdaboi318; Mar 1, 2009 at 10:03 PM. Reason: Automerged Doublepost
I'd say you should spend some more time at the track before you get a tune. It will only get harder when you have more hp/tq and potentially harmful to your car.
1. At what rpm are you launching?
2. Are you feathering or dropping the clutch?
3. How long are your wheels spinning or are you bogging?
4. Did you lower your front tire pressure?
its just a vavle cover leak. its covered under your powertrain warranty, which includes all gaskets up to 60K on the manafactures waranty. Dont let the dealer lie to you and call it normal sipeage like they try to me. im a mechanic so i know better. their getting a letter from the Better business beareau from me. its an easy fix, you could do it yourself (i guess).
2. I did both. but feathering works best.
3. Wheels spin through 1st and 2nd sometimes
4. Tire pressure was down to 15 psi both fronts..
They need to prep that track better if you are spinning in 2nd stock. My car will spin in 2nd on the street but if they have enough VHT down it should hook in 2nd IDK about 1st though. Stock my car had no spin at all in 2nd and very little in 1st on the street. The track prep was bad apparently.
