which one would you buy.....?
Old Sep 11, 2012 | 08:57 PM
slvrred-'s Avatar
Now i may be opening a can of worms with this one, but i wanted to know what everyone thinks. Now there are two SERIOUS upgrade turbo's for the lnf.
First up that more people are aware of is ZZP's ZFR
Link: ZZPerformance - ZFR Turbo #ZZ-ZFR
And then there is Pwerks or performance auto werks's turbo the WR-2.
Link: The Home of WERKSracing products!
Now both companies offer both turbo's as a bolt on for the lnf and come with all parts needed to installed without modification to your current set up, if your on the stock turbo. Price wise both turbo around the same price. and they both offer around the same horsepower level, depending on your tune of course. Which would you choose and why? I really cant decide which i would want as an upgrade for this upcoming spring when i plan on doing a turbo swap. I'm leaning towards the WR-2 do to the more stock look and size of it.......
so this begs the question, which one would you choose and why?
Old Sep 11, 2012 | 09:07 PM
tomj77's Avatar
only the zfr, dont even know what kinda turbo the other one is, probably stock with bigger wheel
Old Sep 11, 2012 | 09:15 PM
slvrred-'s Avatar
the only thing stock about the WR-2 is the housings. they have been opened up the housings to fit the precision dual ball bearing center section.
Old Sep 12, 2012 | 12:15 AM
tomj77's Avatar
id still go with zfr, cheaper, newer tech, makes more power
Old Sep 12, 2012 | 08:47 PM
slvrred-'s Avatar
after core return on the wr-2 they are the same price and make the same power....
Old Sep 12, 2012 | 09:01 PM
Sonicyeller's Avatar
Well then the ZFR is technically cheaper if you sell your used K04 that comes off. There, question answered. ZFR makes the "same power" (per you) and costs less once you make a few hundred off your good/working stock K04.
Old Sep 12, 2012 | 09:11 PM
tomj77's Avatar
i dont like returning cores. lol id still go zfr
Old Sep 12, 2012 | 09:54 PM
slvrred-'s Avatar
i was thinking that myself but i could always pick up blown ko4's off here for cheap to send in and keep my stocker around incase i decide to part out one day. IDK, i've seen both turbo's in person and the ZFR is a hugh turbo and gives away the "sleeper" stock look of it. The WR-2 has the same size but more punch.......idk......i cant ever decide....
Old Sep 12, 2012 | 10:24 PM
SSlobalt's Avatar
Most K04's on here will have the cracked dual-scroll manifold, so I wonder if they would even accept that. Also, it's not about peak numbers, it's about he area under the curve. My guess is that the EFR has a much larger area.
Old Sep 12, 2012 | 10:28 PM
slvrred-'s Avatar
if your talking about the middle section inside the hotside, i pretty sure thats normal of most twin scroll turbos. I have asked them about core return and as long as the exhaust and intake housings are completely shot from shaft play and someone running too long like that, they will take them. I'd really like to see a compressor map for the wr-2 but have yet to see one......
Old Sep 13, 2012 | 02:35 AM
Fastgti69's Avatar
Zfr
Old Sep 13, 2012 | 02:37 AM
Oboma's Avatar
zfr
Old Sep 13, 2012 | 02:52 AM
alerosaint's Avatar
Zfr
Old Sep 13, 2012 | 09:05 AM
user 72239's Avatar
yeah I'd say ZFR. the WR-2 is nice I'd like to keep my k04 just in case.
Old Sep 13, 2012 | 09:38 AM
Balt_and_Vette's Avatar
Wr-2
Old Sep 13, 2012 | 09:49 AM
C_A_D88's Avatar
Contact pwerks they now have a wr3 in the making
Old Sep 13, 2012 | 09:32 PM
slvrred-'s Avatar
^^^^ i take it that they starting making there "wr-3" with and an efr style turbo since they have been come available again......thats my guess on it.
Old Sep 14, 2012 | 08:25 PM
Frogstofall's Avatar
I HIGHLY doubt that...
Old Sep 14, 2012 | 10:01 PM
MS3 2 SSTC's Avatar
Zfr!!
Old Sep 14, 2012 | 10:07 PM
reduf99's Avatar
sjc0013 Licks windows
Zzp and the ZFR ftw
Old Sep 16, 2012 | 08:27 AM
cw383's Avatar
Im interested in that ZFR setup. Any ideas what it would do powerwise with stock cams and 93?
Old Sep 16, 2012 | 02:16 PM
SSlobalt's Avatar
Originally Posted by cw383
Im interested in that ZFR setup. Any ideas what it would do powerwis with stock cams and 93?
391 hp / 400 tq.
Old Sep 16, 2012 | 04:51 PM
cw383's Avatar
Hey SSlobalt, that sounds like just what I'm after. Was that WHP? Can I find any info on you're source?
NOLAGSS
Apr 5, 2009 06:33 PM
