P.o.s.
P.o.s.
well i was just wondering if anyone knew why my car bogs on startup now if it's cold and i start it it'll bog down almost killing itself. I wanna blow this tempermental pos up. It's just problem after problem
how badly does it bog? my car does that... it has a slight bog when it's first started...just let it idle until the fast idle goes back down to 750rpm and you'll be fine... maybe the car runs a little rich when it's warming up?... really shouldn't bog or anything anymore after about 20-30 seconds of idling.
car runs rich at startup to warm up the cat. its called cat warmup mode for about 30 seconds. if u have dashdaq , if u watch the fuel rail pressure, on cold startup at idle its about 1500 psi for 30 seconds cause its dumping a lot of fuel into to motor to warm up cat quickly. i wait till it drops back down to about 500 psi and the boost goes down to -20ish then ur good to go. just dont get on it for awhile either or ull misfire, gotta let the oil warm up to which takes about 10 minutes till its about 170 degrees. then ur good to stomp on it. hope this helps u
Iambroke: i have full 3 inch catless turbo back, selectible trifecta, injen cp, synapse ic.
cobaltdaddy: it nearly kills itself
orbalt08: i usually do but i don't have cat's anymore
tomj77: thanks so it's normal?? huh it just started doing it ever since i had my map replaced and put my new ic on do i need to retune for the ic?? it doesn't seem to run as good
its normal AJ. how much gas do you have in your tank? i find when i am very low it bogs more then when there is over half.
It'll go away. and does it really matter? just start your car and let it run for a bit..dont start driving it.
k thanks jp and i was just wondering because it just started doing it
holy crap i thought it was just me. seems to not do it lately, but after i went catless after the initial start it would bog to like 500rpms and puff a little black smoke out, then idle real high and go into cat warmup mode. lately it hasnt, but its funny you mention the whole gas thing b/c i feel like i used to drive around with no gas all the time. now when i put gas in my car my EVAP thign is going bad and it takes 3 cranks to start my car.
mine did this 2 days in a row...didnt know what it was maybe becuase of the cold weather since it sat out there for a week as soon as i put it back inside the garage in didnt do it anymore...not sayin that was the cause but im just throwin it out there
My car dies out on cold starts once in awhile, after the 2nd start it surges awhile till it warms up. I just let warm up till I can hear the ticking noise comming from the DI, then I know its good to drive.
I have a trifecta tune and a K&N drop in.
My car started doing that as the weather was starting to get colder but now that the temps are not fluxuating as rapidly it starts fine now. When first starting with one tap would kinda studder for a second and then rev up to high idle.
I know on an HPTuned car, if you change the DAL table below 40ish%, they go crazy surging/stalling in cold weather. I don't know if the trifecta tune changes things below there or not.
Sonicyeller
Feb 8, 2014 03:36 PM
