P0011 & P0010 help please!
Old Aug 21, 2013 | 09:56 AM
RAIDERNATION 433's Avatar
So the CEL keeps turning on and off every few days or so. Where is the stupid cam sensor? Is it hard to replace? do I need A new one or is something loose? Whaere can I get I new one. Anything you guys ang gals have to help A brother out would be greatly appericated. Thanks!
Old Aug 21, 2013 | 10:03 AM
dcrep06's Avatar
simple to replace, just did my two about two weeks ago. they are the sensors that go through your valve cover. probably just need new ones, about 40 each. i got mine through the dealer at cost cuz i know someone so may be a little more for you. just change them though, you will be good after that lol.
Old Aug 21, 2013 | 10:19 AM
Sox-Fan's Avatar
Got Brakes?
you need an extension, a 10mm socket, and 10 minutes. Sometimes the screens get clogged, but if you've been doing your oil changes on schedule that's probably not the issue. They are mechanical items, they wear. Cheap to replace though, and super easy to do. Top of the valve cover, you'll see them to the left of the cylinder 1 spark plug.
Old Aug 21, 2013 | 10:28 AM
Sweet, Thanks!
Lol I just found this link on the site as well
https://www.cobaltss.net/forums/how-...roblem-288938/
Last edited by RAIDERNATION 433; Aug 21, 2013 at 10:28 AM. Reason: Automerged Doublepost
Old Aug 21, 2013 | 02:22 PM
dcrep06's Avatar
Originally Posted by RAIDERNATION 433
Sweet, Thanks!
Old Aug 21, 2013 | 02:32 PM
chevygirl2006's Avatar
I have the same codes lol
Old Aug 21, 2013 | 03:27 PM
dcrep06's Avatar
easy 10min fix lol
Old Aug 21, 2013 | 03:36 PM
After I order the actuators
Old Aug 21, 2013 | 04:00 PM
Cherry GT's Avatar
Its the actuator sensor that is on top of valve cover....
The actuator is on the camshaft.....
My sensor wouldn't pop out of its hole till the engine cooled off,
so maybe you have to do it cool.
Old Aug 21, 2013 | 04:28 PM
They are called actuator solenoids. The ones on the cam are called cam actuators.
Old Aug 21, 2013 | 04:32 PM
http://item.mobileweb.ebay.com/viewi...d=261154087036
Old Nov 10, 2013 | 07:29 AM
LotusRenaultF1's Avatar
I replaced my intake position sensor but can't find the exhaust sensor. I'm assuming cylinder 4 is on the driver's side because that's where the intake sensor was.
Old Nov 10, 2013 | 12:14 PM
They are right next to each other on passenger side on top of the valve cover.
imperialblueSS
Jul 6, 2015 10:34 PM
unijabnx2000
2.2L LAP Performance Tech
Aug 9, 2014 12:49 PM
Hammbones
May 11, 2011 06:22 PM
rukkee
Jul 9, 2010 05:55 PM
rukkee
Sep 21, 2009 06:47 PM
