P2261 with GFB DV+
Old Aug 1, 2023 | 09:37 AM
i8acobra's Avatar
P2261 with GFB DV+
Okay... 2009 SS... Two week ago, I installed a GFB DV+ along with a ZZP intake and exhaust. I had the preload screw set pretty tight and popped a P2261 for the bpv sticking. I figured the ECM was interpreting the bpv delayed opening as a sticking problem, so I backed out the preload. Set the code again. Backed it out almost all the way, set the code again. Now I know the point of the aftermarket bpv is to stay closed longer to prevent boost leakage (I'm an ASE Master Tech and have been building high HP cars for decades). Is this just something you have to live with with a GFB DV+? I don't mind really as it doesn't affect driveability. I just don't like having lights on the dash. It only takes about 5 minutes to swap the stock one back in to pass smog, just an annoyance I'd like to deal with if it can be dealt with.
Old Aug 1, 2023 | 10:14 AM
Haven't heard of many running GFB parts on the cobalts, but I would double check the stupid simple stuff, like the solenoid plug, vacuum lines/routing, etc. Another quick test is to rev it up in neutral and see if you get a turkey gobbling or Zoidberg sound when you left off, or if you get this sound anytime when letting off after building some boost.
Old Aug 1, 2023 | 10:50 AM
i8acobra's Avatar
It's nothing outside of the bpv itself. With the stock one, I don't get the code. If it was a hose or solenoid, I'd have the code with both. I only get the normal bpv "whoosh" when letting off. I have the ZZP intake, so it's very audible.
Old Aug 1, 2023 | 12:50 PM
It wasn't clear that you had swapped the stock back in and the code went away.
If you get the normal bpv sound from the GFB part, then it's likely the GFB bpv is doing something the ECU doesn't like so either live with the light or shut the code off in hptuners.
Old Aug 1, 2023 | 01:17 PM
i8acobra's Avatar
That's probably what I'll do. I have the Prolink cable and the software. Just haven't tuned an Ecotec before, and don't own a dyno. Trying to find a tuner local to me in Vegas.
Old Aug 3, 2023 | 07:27 PM
AfterShok's Avatar
There's a select few i'd trust with tuning these cars especially an LNF. Lots do remote tuning where you send your data logs to a tuner and they send you a revised calibration through hptuners.
Old Nov 8, 2025 | 03:34 AM
DeanSsspsh's Avatar
I have an 08 cobalt ss and i also have the GFB DV+. I had the same problem as you getting the p2261 code. I've come to find that if you put the stock bypass valve spring in the code won't come back. I've been running it that way for months no problems no codes. Awesome valve
reybalt
Oct 12, 2015 08:30 AM
Wangspeed
May 6, 2015 04:27 PM
d.j.wagner1991
Aug 11, 2014 11:15 PM
gotboost?17
22
Aug 20, 2013 06:13 PM
trainplane3
Jun 25, 2013 06:02 PM
