Pre-Build Checklist
Old Apr 19, 2011 | 11:38 PM
JustACobalt's Avatar
Pre-Build Checklist
alright as im getting ready to replace a burnt piston, i just want to gather all the special tools i will need to get the job done. so far i have:
feeler gauge
cylinder bore gauge
micrometer
beam-style torque wrench
flex-hone tool
piston ring compressor
does anybody have anything to add?
Old Apr 19, 2011 | 11:43 PM
LS6Rally's Avatar
Plasti gauge - should check your bearing clearances while you're in there.
and a drill for the hone
Old Apr 19, 2011 | 11:48 PM
eh i think im ok with the bearing clearances. nifty tool tho...
i think i might have them all
Old Apr 19, 2011 | 11:52 PM
LS6Rally's Avatar
do you have stuff to put over the rod studs so you dont score the crank or cylinder walls when re-installing the piston?
Old Apr 20, 2011 | 12:33 AM
Sox-Fan's Avatar
Got Brakes?
Are you going to have to adjust your rings? ring file?
Old Apr 20, 2011 | 12:36 AM
im going to hold up on the ring file and just buy one on the spot in the case that they arent gapped correctly.
for the rod studs, i can just wrap them with painters tape or something, no biggie.
Old Apr 21, 2011 | 10:24 PM
bump. never rebuilt an lnf. if somebody has can they chime in!
EvilOni22
Jul 19, 2013 03:24 PM
09sscalicobalt
May 5, 2012 11:55 PM
popeye55
Mar 2, 2009 02:11 PM
Cobalt(312)
Mar 30, 2008 11:35 PM
