Problem Starting When I Get Gas
Old 05-08-2012, 11:37 PM
jfem92's Avatar
So my problem is very simple to explain and I am curious if any LNF owners ever experienced this issue and/or have any logical solutions. Whenever I get gas, no matter 87, 89, or 93 (always 93 but tried the others just to test), when I start the car up to leave the pump it cranks for maybe 5-10 seconds and struggles to start. Once started it has a rough idle around 900rpm and then it's fine when I drive away, start it again, etc. At first I thought it was bad gas or something but after a few times doing so I started to notice it was becoming a trend. It is a 2008 ss/tc with abount 21,800 miles. I'm probably going to replace the fuel filter tomorrow and try getting gas but it shouldn't need replacing with low miles like my car has. Any help would be greatly appreciated, especially so I don't look like a moron when I get gas in about a week! ~Jordan F.
Old 05-08-2012, 11:41 PM
FasterIsBetter's Avatar
Purge valve solenoid. Try unplugging the electrical connector going to the solenoid on the very front top of your manifold. It will have a plastic evap line running to it.
Old 05-08-2012, 11:46 PM
n0xid's Avatar
Are you adding more gas once it clicks? If so, don't.
Old 05-08-2012, 11:53 PM
I'm too JDM for you
BLAZIN07SS's Avatar
It's definitely the purge solenoid in the engine bay
Old 05-08-2012, 11:58 PM
jfem92's Avatar
What exactly would I be doing tomorrow when I unplug the purge solenoid. Not quite familiar with this.
Old 05-09-2012, 12:04 AM
Just unplug the electrical connector on the solenoid itself. Then go fill up with gas and see if that solves your issues.
Old 05-09-2012, 12:11 AM
jfem92's Avatar
Alright hopefully this is what the issue is, thanks guys for the insight, great video i just found also explaining for anyone who looks at this with the same issue
DDMWorks - EVAP Solenoid Testing and Replacement on Ecotec engines - YouTube
Old 05-11-2012, 01:59 PM
lockdownlegend's Avatar
its not the purge solenoid its the evap valve thats located by the gas tank. i can promise you this if its only when you get gas
Old 05-11-2012, 02:14 PM
nwss's Avatar
its the little black a blue thing to the right of the valve cover, trust me if youre asking this question just listen to us that have changed them more then once lol just go buy the new part and replace it. im not wrong
Old 05-11-2012, 02:16 PM
where is this on the lsj engine ? i'm having the same excact problem except its not when i get gas, more like when my cars just been off for a while,. trying to determine if it s the fuel pump or something else
Old 05-11-2012, 02:30 PM
user 72239's Avatar
This, mine did the same problem. Replaced EVAP Purge solenoid on manifold. fixed
Old 05-11-2012, 02:34 PM
nwss's Avatar
right side of the vavle cover and has two hoses coming out of it, one goes into the sc and one into the intake manifold
Old 05-11-2012, 02:37 PM
^^thanks man
bigdeertz
11-17-2016 09:41 AM
brandon04
10-21-2015 07:04 AM
DocSvensk
09-27-2015 02:24 PM
Adiaz1ss
09-26-2015 11:51 PM
OrangeK
09-20-2015 03:02 AM
Quick Reply: Problem Starting When I Get Gas
