Pte5858 install
Old Dec 31, 2012 | 03:08 AM
etnies's Avatar
Pte5858 install
Ok I've been checking out my turbo and I noticed the only vacuum line is on the compresser housing. It's the first turbo besides stock that I've installed and I know the stock turbo has a vacuum that bolts to the valve cover and the pte doesn't have a spot for this so will I just put a filter on the valve cover or run it in with something else
Old Dec 31, 2012 | 03:09 AM
CoOl.
Old Dec 31, 2012 | 03:14 AM
etnies's Avatar
? -_-
Old Dec 31, 2012 | 03:16 AM
i dont see a question lol. just kindof a statement of randomness
noorj's Avatar
That is not a vacuum line on the compressor housing, that will see boost and you do not want to pressurize your crankcase. You can either put a filter on the VC or tap into the intake for vacuum, I would suggest taping into the intake.
Old Dec 31, 2012 | 03:25 AM
etnies's Avatar
It was at the end I was wondering what to do with the line that ran from the valve cover to the stock turbo but the other guy has answered it already
Old Dec 31, 2012 | 03:28 AM
etnies's Avatar
So as far as the stocker was this line hereto equalize the pressures in the turbo center housing with the vc?
Old Dec 31, 2012 | 03:34 AM
noorj's Avatar
I though we were talking about vacuum lines? There are no vacuum lines from the VC to the center cartridge, that would be either oil or water. I'm assuming that turbos only oil cooled so the water lines can just be plugged and hook up the oil lines.
Old Dec 31, 2012 | 03:41 AM
etnies's Avatar
Let me get a picture. If I can't find one ill take one tomorrow and upload it
Old Dec 31, 2012 | 03:55 AM
etnies's Avatar
It is that nipple on the compressor side that is bolted down by one bolt.
Old Dec 31, 2012 | 09:57 AM
ford's Avatar
If you don't have an answer when i get home ill just provide you some pics of how it should be setup or look at your photo and point it out.
Old Dec 31, 2012 | 10:47 AM
prevsrt4owner's Avatar
What Ford said. Best reply.
Old Dec 31, 2012 | 10:56 AM
cubaniche's Avatar
The line that goes from the corner of the VC to the stock turbo is a vaccum source to help pull crankcase pressure out as it doesnt do a very good job on its own of relieving crankase pressure, especially under boost. You want to tap the intake as close to the mouth of the turbo as possible to attach the line from the VC to. This way, when you are in boost the suction will help pull the crankcase pressure down so it doest build up and make your pistons fight building pressure down below.
You can vent that VC to atmosphere if youd like, but I wouldnt leave it like that indefinitely.
Old Dec 31, 2012 | 02:10 PM
etnies's Avatar
Thanks guys this answers a lot I've been wondering as I'm probably 2 or 3 days from having my money and ordering the rest of my parts which means its bout time to start the build!
Thanks guys
Old Dec 31, 2012 | 02:14 PM
Frogstofall's Avatar
I would also recommend finding someone who knows what they are doing and have them look your car over before you drive it. Post pictures when you can!
Old Jan 1, 2013 | 01:59 AM
etnies's Avatar
I have a certified mechanic who's helping with the build and he knows quite a bit from what I've gathered just from discussing the build with him. Although he hasn't dealt with a turbo before. I will be sure to take plenty of pics and the car won't be started till I take it to ccss3 for the base tune cuz I have a stock tune right now and have three bar sensors. Needless to say it's not being drivin till I get my hands on a proper base tune
Old Jan 1, 2013 | 02:02 AM
etnies's Avatar
Oh yea and I got my overtime paycheck so first thing in the am I'm placing my order with ZZP. I'm sure they aren't going to be there on New Years or I'd just call and order it instead of going online
Old Jan 1, 2013 | 02:36 AM
What all are you ordering?
Old Jan 1, 2013 | 02:48 AM
etnies's Avatar
Rotated trans mounts
Billet engine mount
Arp studs
New head gasket
Dual scan gauges
Wiseco pistons
Zzp rods
Stage 1 cams with larger fuel lobe
82# valve springs
Clutch alignment tool (already bought stage 3 ky clutch)
Rod and crank bearings
New oem flywheel with new own bolts
Zzps oil squirters
6 quart break in oil
And rvt high temp gasket maker for the precision turbo kit
Old Jan 1, 2013 | 02:51 AM
etnies's Avatar
My goal is a lil more than 400whp that will be safe and last a long time
Old Jan 1, 2013 | 11:57 AM
Nice list. You ever torn apart a motor before?
Old Jan 1, 2013 | 03:07 PM
Nfamous60's Avatar
sweet list
Old Jan 1, 2013 | 04:32 PM
etnies's Avatar
A couple atvs and a Dirtbike and put a clutch in my Honda. I have a basic knowledge and like I was saying my buddy does it for a living and he'll be there helping the whole way. He just finished his trans am. Don't know what cam is in it but its a beast
The only thing I'm nervous about is honing the cylinders and I may just make him do it
Old Jan 1, 2013 | 04:33 PM
etnies's Avatar
Well the parts are paid for. All that's left is for Zzp to ship them after the holidays cuz they were all in stock
Old Jan 1, 2013 | 06:00 PM
ford's Avatar
Did you figure out how to run that vacuum line?
