Pushing for 700HP!!
#201
la la la la la la la la laaaaaaaaaaaaaaaaaaaaaaaaa
A few questions, the problem with the nitrous causing you to run out of fuel/low pressure, Couldnt you lower the jets-run a smaller shot, Therefor give the engine more fuel for the turbo????
2. Where is your nozzle locatied? TB spacer? in the charge piping? intake manifold?
3. I know that HAHN had the port injection Intake Manifold, Why couldnt you do something like that, But at the same time, have it set up with another fuel pump, either in the tank, or even a fuel cell, Where you can use say 93, and when you go WOT you have 4 injectors spraying E85,
So it would almost be like using meth, But i do know, there arnt very many people that will have a fuel cell, in there car, But just a idea
And again, Where is the love at, Everyone is trying to do the same thing, GO FAST........ There are alot of people that fuss about the prices of parts being so much, But when there are 1 or 2 companys that really try hard to make parts it will end up loweing the cost... Like cams Not everyone will pay $850 for cams, Really, when you can get cams with the Fuel lobe for $200, Iam just using that as an example.
This is just my .02
This is just my .02
