question about where to buy 2 step?!
ZZP launches like that cause they are running a big slick and they use the neutral rev limiter which doesnt build boost, hence launching at a higher rpm. You can launch around 3000 on stock turbo and get a much better launch than on the stock 2 step at 5000. On the stock 2 step I was still only cutting 1.9's. That could be do to a partial slipping clutch, or the fact of not having boost for that second on the launch. We ended up putting the wot shift at 200ms and manual mode and its not bad now.
