Quick, possibly silly question
Old Sep 6, 2012 | 04:38 PM
casionerd's Avatar
village idiot
The outside temperature displayed on my dash is sometimes correct but usually it's wrong. Sometimes it's off by ten degrees or more. I'm pretty sure that the dash temperature sensor is in the fender behind the driver's side headlight and isn't tied to any temp sensor that could affect fuel trims or anything but I wanted to make sure. The timing or whatever is dictated by the MAF right?
Let me know if I'm wrong and should be concerned or not.
Thanks.
Old Sep 6, 2012 | 04:40 PM
Stamina's Avatar
By dash, do you mean RPD? And by temperature, do you mean outside or intake air temp?
If you're talking about the "Intake Air Temp" on the RPD, then that is the IAT2 (post intercooler) temp taken by the TMAP in the coldside pipe and affects timing and such. You may notice the RPD temp displayed lag a bit behind another gauge monitoring the same thing at times because it has some smoothing built into the reading.
Old Sep 6, 2012 | 04:41 PM
casionerd's Avatar
village idiot
The green display that shows odometer, tire pressure, etc.
Old Sep 6, 2012 | 04:44 PM
Stamina's Avatar
Oh okay, the DIC. No, that temp is the outside/ambient temp. Now that one does use the temp probe you're referring to. It doesn't really affect timing, nor is it associated with the MAF in any way.
That will most likely be lower than your IAT1/IAT2 temps most of the time.
Old Sep 6, 2012 | 04:46 PM
casionerd's Avatar
village idiot
Thanks for helping so quickly.
Old Sep 6, 2012 | 04:48 PM
Stamina's Avatar
No problem man.
Now keep on keepin' on.
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Tupp
Sep 30, 2015 08:18 PM
OPCrer
Sep 27, 2015 08:11 PM
