Quick question
Quick question
I dont recall ever seeing the answer to this on the forums, so here it goes. Does the LNF finally have a return style fuel system? or is the DI a returnless fuel system as well...
on a return style system, the pump will supply say 60psi of fuel to one end of the fuel rail, and there will be a sensor at the other end of the fuel rail to ensure there is still 60psi of pressure before the remaining fuel that was not used in the injectors returns to the fuel tank. On a return-less style, there is nothing after cyl #4, so its very possible for cyl 1 to have 60psi, cyl 2 to have 60psi, cyl 3 to have 60psi, and cyl 4 to have, say 55psi, as all the fuel would have entered the first 3 injectors and not enough remains to enter the 4th at the same value.
At the end of the day, it can lead to uneven distributions of fuel for each cylinder...making it a bitch to tune, since widebands will show the average AFR for all 4 cylinders, instead of showing cyl 1 runs 11.5:1, cyl 2 runs 11.5:1, cyl 3 runs 11.5:1, and cyl 4 runs 12.8:1 AFR, when the wideband will just display a seemingly safe AFR of 11.8:1
this is one of the contibuting factors to highly modified LSJs always seeming to blow cyl #4 and none of the others
Thanks for the very informative post
also
the in-tank fuel pump provides fuel to the engine at the 58psi stated, then the cam driven pump increases the pressure as needed for overcoming combustion pressure. otherwise air would enter the fuel system
That's not true, if air enters at 14.4 psi (naturally aspirated DI engine) with a compression ratio of 10:1 it will increase to 144 psi. You don't need 1000+ psi to overcome 144 psi. The reason is for fine atomization of fuel. After combustion when the cylinder pressure rises the injector is shut.
