Quick Question
Old Jan 13, 2010 | 04:37 AM
Leveecius's Avatar
Quick Question
Ok, I'm probably going to get flamed for this pretty bad, but what exactly is the "pill mod"? I've never heard of this and when I searched for it, I didn't find anything. Can anyone fill me in on this topic? All I know is that it's kinda like a MBC..
Old Jan 13, 2010 | 04:51 AM
ChriSS/SC's Avatar
Idk what that is either
Old Jan 13, 2010 | 05:03 AM
BartSS's Avatar
Pm byt he's running it. I can kinda explain it but I don't wanna be wrong. I know it has to do with a welding tip and you insert it into a line that goes to the turbo n what not. U won't get flamed this isthe reason forums exist. But of course there are some dumb ***** that will be like haha u noob **** em though
Old Jan 13, 2010 | 07:30 AM
SSlobalt's Avatar
Welding tip in the waste gate tube. You have to be tuned for it, so don't try it unless you are going to tune the car for it.
Old Jan 13, 2010 | 08:49 AM
Leveecius's Avatar
I'm not saying I'm going to be trying it, I'm already getting a 3076 for the car anyways, I was just wondering what it does and how it works.. I've never heard of this except from a few people that have mentioned it.
Old Jan 13, 2010 | 07:06 PM
tomj77's Avatar
it basically just raises u boost, like a boost controler, why they dont just run a tune with higher psi instead of waisting time doing that since they have to tune it anyway, i dont know. sounds like a exrta step that doesnt have to be there to me.
Old Jan 13, 2010 | 07:32 PM
Iam Broke's Avatar
A small opening MIG welding tip, like an .030 for instance inserted in one of the lines going to the boost control solenoid restricts the flow slowing the opening of the wastegate and raising the boost. You need to be able to reprogram the Desired Air Load table (DAL) with HP Tuners ect to control the amount of boost.
This is a workaround since we don't have wastegate control in the HPTuner's software. It raises boost in the midrange the most (at least mine does). The boost still tapers off as you approach redline when the turbo gets tapped out.
The welding tip is nicknamed the pill.
Hope that helps a bit.
Old Jan 14, 2010 | 12:25 AM
Leveecius's Avatar
Thank you!! I now understand. That's a good idea, but does it make the turbo unefficient running at such higher boost levels? I heard our turbos are only efficient to 23psi.
Old Jan 14, 2010 | 08:02 AM
Iam Broke's Avatar
That's why it runs out of gas up top, it gets off the sweet part of the curve.
Old Jan 14, 2010 | 10:09 AM
BYT*SS*TURBO's Avatar
There is a thread on it in the tuning section.
BTF claims the stock turbo is efficient to 35psi in the low-mid range. You need to be back around 20-22 by 6K.
Old Jan 14, 2010 | 10:47 AM
Leveecius's Avatar
That's good stuff. Any dyno sheets to show the performance of this setup?
Old Jan 14, 2010 | 11:09 AM
Yup. ~50whp thru the midrange gain, minimal up top on my last dyno session.
Old Jan 14, 2010 | 12:07 PM
Iam Broke's Avatar
Take the pill and buy a clutch.
Old Jan 14, 2010 | 12:10 PM
copson20's Avatar
https://www.cobaltss.net/forums/tuning-131/pill-mod-195156/
Old Jan 14, 2010 | 02:31 PM
QFT!!!
Do a 2nd gear burnout and listen to that clutch cry....then let it cool and drive it easy for a lil. Worked like a champ in my car, Im able to hold WOT in 5th at any RPM.
Old Jan 14, 2010 | 03:19 PM
Iam Broke's Avatar
Originally Posted by BYT*SS*TURBO
QFT!!!
You must have turned the clutch plate into sticky stuff.
If I get brave....
Old Jan 14, 2010 | 06:48 PM
tomj77's Avatar
seriously u guy with the pill mod, why do u need it when u can just raise the boost in ur tune? i mean ur tuneing it anyway, why the extra step, i dont get it, is there any benifit to do it like that instead of just raising the psi in the ecu?
Old Jan 14, 2010 | 06:57 PM
Iam Broke's Avatar
There are tables not accessible to us with HPT so the only way to get more than 22 psi boost is to fool the boost control solenoid into thinking it has less boost than actual so it will raise the output.
Old Jan 14, 2010 | 07:41 PM
tomj77's Avatar
ok i see now. its just guys with hpt that have the problem.
Old Jan 14, 2010 | 08:43 PM
Iam Broke's Avatar
Some call it a problem, others an opportunity. I prefer to work on my own tune, thank you.
Old Jan 15, 2010 | 08:34 AM
Major problem, takes all of 10 minutes and a $2 part to correct it lol.
Old Jan 15, 2010 | 09:35 AM
Terminator2's Avatar
It is these so called problems that create innovation and new ideas. I would never recommend the pill mod to anyone who does not have access to, or is not a competent tuner.
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
