Radiator fluid coming out my exhaust a good thing?
Old Aug 6, 2011 | 12:50 PM
txcobaltss254's Avatar
Need help, radiator fluid is coming out of my exhaust not a lot but enough to notice. Was wondering what it could be, I'm thinking it's either a blown head gasket or A blown gasket on the turbo I would appreciate any input
Old Aug 6, 2011 | 12:52 PM
TommyP's Avatar
AWD > FWD
You're SURE it's coolant? it could just be water or unburnt fuel.
Old Aug 6, 2011 | 01:39 PM
Na it's not water or unburned fuel, it's a bright orange fluid and that could only be one thing radiator fluid
Old Aug 6, 2011 | 01:59 PM
slvrred-'s Avatar
if your sure its coolant and not water then i would say that you have a bad/blown seal in your turbo......but to my guess is that it would smoke alot too.....if it isn't the turbo then it could be your headgasket but you would know that cuz the car most likely wouldn't run very good.
Old Aug 6, 2011 | 02:01 PM
zrated89's Avatar
do a compression / leak down test to eliminate the head ( if you have access to a block tester that would be easier) then i would assume its your seal in the turbo
Old Aug 6, 2011 | 02:03 PM
BPacak's Avatar
Vtec Rep
yeah thats not good haha.
Old Aug 6, 2011 | 04:33 PM
sLAsh's Avatar
If it's antifreeze the exhaust should smell sweet.
Old Aug 6, 2011 | 05:49 PM
09BlueBaltSS's Avatar
Check the oil for water contamination(milky colored) The car should be smoking if either seal is leaking. Are on stock exhaust? Do you just see water for the first couple minutes after the car is turned on or does it not stop?
Old Aug 6, 2011 | 06:05 PM
cmiller8006's Avatar
I believe if the head gasket was leaking then you would have white smoke, Since your saying it still looks orange then I would guess the turbo seals are blown, since if it was a hg then it would be super heated in the combustion chamber and be a steam.
Old Aug 6, 2011 | 07:16 PM
Oil is good, I got side mount exhaust and the only seen twice a little puff of smoke and if the turbo has a bad gasket shouldn't I feel it in performance wise because before I knew I was leaking fluid through my exhaust I was at the track and my car was running on point I mean l live here in Texas were like the heat will melt your face and I ran a 13.4
Old Aug 6, 2011 | 07:39 PM
SSlobalt's Avatar
You can pick up a used K04 on here for around $250, usually, if you're not under warranty. I have an extra sitting in my garage in case this happens to me.
Old Aug 6, 2011 | 07:48 PM
T-Man's Avatar
Hell yea brohammer, you're just extracting mad power. The more you see coming out, the faster you're going to be!
Old Aug 6, 2011 | 08:29 PM
If it was the turbo it would either leak into the compressor side, get ingested by the motor and make white smoke(not heavy) and if it was leaking into the turbine side it would get burned off by the hot exhaust gases which would again make white smoke.
Is your exhaust aluminized steel? Maybe the condensation that builds up when the car is off is rusting the inside of the piping thus making the water look orange?
Old Aug 7, 2011 | 01:31 PM
I wish it was rush it would be a lot easyer fix but I just brough the exhaust 3 weeks ago so it can't be that. And I've only seen like 2 small puffs of smoke when I start it up.
Old Aug 7, 2011 | 03:48 PM
T-Man's Avatar
This sounds like a possibility, considering the short length of a side exist exhaust.
Old Aug 7, 2011 | 04:10 PM
AndrewSS/TC's Avatar
Dont forget to check your blinker fluid when you check your radiator fluid.
Old Aug 8, 2011 | 12:27 AM
exninja's Avatar
Is this really necessary??
I would think that if there's enough coolant to be dripping out of your exhaust then you'd notice that in your reservoir. Have you collected some and made sure that it's coolant? When do you notice the leak? If it's condensation, intuition tells me that it would drip until the exhaust warms up sufficiently and then water wouldn't condense on the exhaust...
Old Aug 8, 2011 | 01:51 AM
I did notice in my reservoir had to refill 3 times in the last 5 days and it's not like it's pouring out my exhaust but you can see the residue of the coolant and plus I can smell it
Old Aug 8, 2011 | 10:26 AM
G Speed's Avatar
why don't you just take it to the delearship?
Old Aug 8, 2011 | 10:34 AM
Prestige_Worldwide's Avatar
^^ I agree
Old Aug 8, 2011 | 10:52 AM
rivaladore's Avatar
How come no one mentioned the possibility of a porous block
Old Aug 8, 2011 | 10:55 AM
bamaboy22's Avatar
How come no one has asked if he's under warranty cause if it's a tv 95% chance he is
Old Aug 8, 2011 | 12:29 PM
svt's Avatar
svt
nah, it's just got a runny nose... try a tissue.
Old Aug 8, 2011 | 12:42 PM
Gremlin85's Avatar
If you're seeing the coolant out the tail pipe of the exhaust, then it's making it's way through there unscaved... This is very odd and unusual.
I would say that its coming through the turbo seal in such large amounts that a small portion of it is making it's way all the way back. If you're filling your resevoir that much, this si very plausible.
::EDITED AFTER READING EVERY POST::
Old Aug 8, 2011 | 01:40 PM
newt's Avatar
You've been noticing coolant coming out of your exhaust, yet you are still driving it hard and taking it to the track and choose not to deal with it till now??
Are you ******* crazy?
"oh hai! My car is leaking nearly 0.5 Liters of coolant out of the exhaust a day...is this bad? Cause I just beat the **** out of my car at the track and its still just as fast!!!11!!!1!!"
*shakes head
