RPD no data
RPD no data
My RPD AFR gauge is saying no data so I am pretty sure the wideband O2 sensor took a crap. All other options for the gauge read fine.
This is the one up by the turbo and not the one coming out of the DP right?
Any one know the part number?
That's the 2nd o2 sensor heater code, rear sensor, shouldn't affect performance or afr display, used to get that ****** every couple hundred miles.... check the wires make sure nothing is damaged and replace the sensor if necessary... they're like $90
as of the no data issue, have you tried turning the car on and off a couple of times and see if it resets? clear all the codes and then check? that code isn't the issue since it's the bank 1 sensor 2 code
also do you have an aftermarket DP?
Yes I have an zzp dp and it throws random codes. It was my bad when I put that p0141.
So thanks anyway
