Sloppy shifter
Sloppy shifter
Well yesterday i noticed while in gear my shifter will move around quite alot. It has never been like this before it just started acting up on me couple days ago. It moves a good amount side to side what can i do to fix this
Sounds like when my shift linkage roll pin broke in the shift assembly in my trans, it would go into gear sloppy. eventually my shifter would do circles. (No more H pattern).
does it look like it is in third when your in first?
I forgot about the bolts
Engine bay by the fuse box. there is a bracket on top of the trans that holds the shift linkage. may have to raise vehicle and go through wheel well.
I think this it what your looking for. It's been a while.
yea my roll pin broke all together and then i only had 4th trying to get across a busy street in only 4th from a stop yea my clutch hates me but got mine fixed under warranty. service manger fought for me cause parts didn't want to do it cause they know i no-lift but he said it tells you how to do it in the owners manule
Did you ever find a fix? My shifter feels the same as you described, but the linkage bracket seems tight.
Cptnslo
Sep 24, 2015 09:32 AM
CannonBalt
Sep 18, 2015 09:13 AM
