smoking under braking??
Old Dec 29, 2010 | 05:26 PM
FrossB's Avatar
Thread Killer
What could cause a car to start smoking and burning oil while pressing the brakes only? like if im coming to a stop and i start pushing the brakes and i get under 10 mph a big puff of smoke comes out of that i think is the exhaust (burning oil). and as soon as im stopped it goes away and once i start accelerating again it doesnt smoke either. WHAT GIVES???
Note: it just had its oil changed..could they have put too much oil in? and why only when i am slowing down?
Old Dec 29, 2010 | 05:27 PM
Turbalt2010's Avatar
sub'd
thats weird id like to know what people think as well.
wish i could help bro but i have no idea at all.
Old Dec 29, 2010 | 06:15 PM
sponge14's Avatar
Are you sure it's oil and not brake fluid? How does the pedal feel? Does it start out firm, but keeping steady pressure on the pedal, does it eventually go to the floor?
Old Dec 29, 2010 | 06:25 PM
batboy's Avatar
First thing I'd do, even before posting this thread, would be to check the oil level.
Old Dec 29, 2010 | 06:37 PM
sponge14's Avatar
And brake fluid level...
Old Dec 29, 2010 | 06:47 PM
ecot3c inside's Avatar
difference is vacuum and boost, but idle should be the same too.
Old Dec 29, 2010 | 07:14 PM
slowbalt84's Avatar
Stop smoking in ur car. Don't wanna burn a hole in ur seat
Old Dec 29, 2010 | 07:20 PM
AndrewSS/TC's Avatar
Burning the muthafuckin brakes off Yo ****.
All joking aside, that's weird I'm curious to know about this.
Old Dec 29, 2010 | 07:24 PM
kxrida2000's Avatar
is ur ebrake possibly up? highly doubt it but its worth a shot
Old Dec 29, 2010 | 07:45 PM
FrossB's Avatar
Thread Killer
E brake is down. and before posting that i should check the oil level..you should assume im bright enough to do that first and to be quite honest..the dipstick wasnt something i had seen before. now this may make me look dumb but it was just a piece of braided cable with no real level indicator on it? so i couldn't really tell. as for the brake fluid..ill have to check that..maybe a brake line is spewing fluid onto the rotors and its burnin it up. cuz the pedals do feel kinda weird but i figured it was just cuz its a new car. ill have to look into that
Old Dec 29, 2010 | 07:58 PM
Cobalt_Daddy's Avatar
subd for answer... sounds like brake fluid
Old Dec 29, 2010 | 08:38 PM
batboy's Avatar
It's the thing with a yellow handle towards the front of the engine is the dipstick. If you don't know how to check the oil, read the owners manual.
Old Dec 29, 2010 | 11:29 PM
FrossB's Avatar
Thread Killer
yea i know what the dipstick is..im not dumb. but all it was was a piece of braided cable..no level indicator at the end...almost like somebody cut it off.
Old Dec 29, 2010 | 11:41 PM
j27-2's Avatar
you should get that checked if it did some how come off you dont want it in your oil pan
Old Dec 30, 2010 | 11:29 PM
FrossB's Avatar
Thread Killer
bump..could this problem be something a catch-can could fix?
Old Jan 2, 2011 | 10:24 PM
FrossB's Avatar
Thread Killer
im pretty sure its coming out the exhaust...any other ideas?
Old Jan 3, 2011 | 02:29 PM
FrossB's Avatar
Thread Killer
bump? anybody have any ideas before i head to the dealer to have them look??
Old Jan 3, 2011 | 09:52 PM
Malaclypse's Avatar
1) Check oil level.
2) Where'd you have it changed and what brand/viscosity did they use? Did they use synthetic?
Old Jan 3, 2011 | 09:57 PM
FrossB's Avatar
Thread Killer
Question...what does the dipstick look like on the LNF's?...cuz i did check it but the dipstick looked weird so i have no clue if its right.
and they put in Mobil 1 5-30
Old Jan 4, 2011 | 09:41 PM
batboy's Avatar
It's the thing with a yellow handle towards the front of the engine.
sheesh
Old Jan 5, 2011 | 02:19 AM
FrossB's Avatar
Thread Killer
sheesh yourself. but dont sweat it. im takin it to the dealer.
Old Jan 5, 2011 | 02:28 AM
HB_SS/TC's Avatar
are you tuned?
if not you prolly need one especially with that Dejon intake
Old Jan 5, 2011 | 02:32 AM
FrossB's Avatar
Thread Killer
Well i bought the car with all these parts on it and it is tuned yes..im guessing HP flavor. it hits 21 psi. but i dont know if it was tuned prior to certain mods or after them all. Regardless i am going to get BYT tuned in February. would a tune fix a smoking problem tho?
Old Jan 5, 2011 | 07:20 AM
batboy's Avatar
Dude, take a couple minutes to read the owners manual and learn how to check the oil. If it's truly smoking through the exhaust between shifts and when you are coasting/braking (high vacuum conditions), that probably means excessive wear in the rings/cylinders. Sounds like this car has probably been abused. In plain English, that means the engine needs rebuilt.
Old Jan 5, 2011 | 08:52 AM
TorqueSSter's Avatar
Kinda Like This.
Kinda hard to read w/ the little ridges as opposed to something that reads FULL, and gives you a line , but it is what it is.
Britt
