so my local muffler shop did a delete for me today :D
and the car sounds great. it had a 3 in down pipe and a 2.5in gm performance exhaust system but it just didnt make any noise so I was convinced to delete the muffler and it sounds deep, rich, and just loud enough to sound good but avoid tickets.....
but would this change my car enough to lean it out without a proper tune?
I have a zzp pcm on the way, I tracked it and its due at my house tomorrow evening so thats on my agenda tomorrow night!
Muffler delete's / "hogzaust" (which is essentially an exhaust leak right before your muffler) are fairly "common" among the Subaru community, never heard of anyone doing it on a Cobalt, but would be interested in a soundclip/vid of the results.
Every car creates back pressure, some exhaust systems create more than others, hence why the call flowmasters choke masters. I did not know a turbocharged car doesnt produce exhaust pulses, wouldnt everycar produce that? Cylinders are still firing and making a pulse.
Post turbo exhaust leaks do not affect performance. The piping is really only there to route exhaust fumes out the back of the car, you could run open from the downpipe and be fine (noise level/fumes not withstanding).
A muffler is put on a car to make it quiet. I know they sell "performance mufflers" but really all they do is make the car louder than stock. Depending on how big it is, shape, how they pack it, baffle materials and so on affects the sound. Think about drag cars, do they use mufflers? No, for a better flowing exhaust
You can basically throw this all out when you start talking about turbocharged engines.
Turbocharged engines do not rely on exhaust scavenging, it is more beneficial to just get boost sooner, the benefits that might be there from exhaust scavenging are out weighed by the torque you will produce by just getting boost ASAP.. You want pressure upstream of the turbo, and as little as possible downstream.
I'd be very interested in a technical explanation of why Turbocharged engines need back pressure.
You would need to look up a flow chart that looks at exhaust vs intake flow. The turbo does in fact decrease volumetric efficiency of the motor due to exhaust manifold pressure, but they also push air in the intake. Many turbos these days actually are so efficient that they cause less exhaust pressure than they make in intake pressure.
the guy i bought it off of claimed it was but the only difference i can tell in it and my 06 cobalt le5 is that the lnf sports 2.5in pipping and a 3in down pipe, now weather or not all lnf's are like that i dont know but my local muffler shop said it was for sure a 3in down pipe and 2.5in exhaust piping
