Spark Plugs
Spark Plugs
I pulled my Stock plugs tonight with about 4 K miles on them
They were quite full of carbon and brownish
I have a shitty pic from my phone i can post
Mods are in my sig
Have you guys been swapping to a cooler plug?
Mods are in my sig
What are they switching to?
Need part number
So after some reading
6509s or 3787s what are better for High Boost levels
Need part number
Take a pic and post it when you can. I'd be curious to see how they look, but generally speaking brown buildup is pretty much a "normal" buildup and usually means you are burning air and fuel effectively and efficiently (good a/f mix). You really shouldn't need to upgrade to a step colder plug with your current mods, but it really doesn't hurt anything if you did.
I was stuck in Reduced Power mode for a ride home after breaking the connector on my High Pressure fuel pump
Just had it fixed
I guess ill clean them up and check the gaps across the board, so stick with the stockers?
Just had it fixed
Those plugs do not look normal. They look a little fouled. They look like they got hot as well.
Stock gap 0.035 works fine as long as you are not seeing over 24 psi. I run 0.030-0.032 in my car. Stock plugs 9K miles on these plugs.
Last edited by Terminator2; Jul 30, 2010 at 03:54 PM. Reason: Automerged Doublepost
... They look like they had a bit too much fuel dumped on them recently and then burned off, but definitely not fouled.
Check this link:
http://www.ngksparkplugs.com/tech_su...qs/faqread.asp
Normal Condition
An engine's condition can be judged by the appearance of the spark plug's firing end. If the firing end of a spark plug is brown or light gray, the condition can be judged to be good and the spark plug is functioning optimally
Dry and Wet Fouling
Although there are many different cases, if the insulation resistance between the center electrode and the shell is over 10 ohms, the engine can be started normally. If the insulation resistance drops to 0 ohms, the firing end is fouled by either wet or dry carbon.
