spark plugs. what are YOU running?
wow they have just about everything lol. Do you think that 3787's are good to run just with the stage1 tune or would recommend factory replacements. People have been saying about going 1 step colder with the 3787 just wondering if that is the plug i should get since i only have stage1. And could someone clarify exactly what does 1 step colder mean?
A colder plug has a shallower depth around the center electrode & porcelain allowing the heat to transfer away from the plug faster, lowering the plug temperature.
If the boost is increased, 1 step colder is suitable.
Code:
http://en.wikipedia.org/wiki/Spark_plug#Heat_range
Interesting. I'm now pushing 24-25lbs. 3787's as one step colder seem to be the favorites here but if NGK recommends the 5476's........? Are THOSE colder too? Whats my best option? Will plugs justify a re-tune?
Well the best i can find is about $45 for the 3787s. Modern Performance has what i believe is a comparable plug for $30. Heres the link http://www.modernperformance.com/iri...bo-p-2013.html Id like some input as to what the difference is other than price.
I ran 6510's (2 ranges colder) for around 15k miles with no issues.
always read the porcelain and ground strap to check heat range..intrested to see if it matches up.
My stockers never lasted that long. I think the longest I went with OEM plugs was about 7k miles before I could tell they needed to be changed.
I run stock plugs.
Tried the platinum in the same heat range, car wouldn't rev past 5k
And whatever the gap is when they come out of the box is the gap I run. Gapping iridiums is a royal PITA.
so i'm at a little over 7k miles on the ss.
i've already got my complimentary oil change, but sometimes i feel it idle a little strangely and am wanting to change the plugs anyways.
what are you guys running and at what gap?
http://www.woodys-auto-supply.com/au...?prod=NGK-3787
i was looking to put these on but not sure at what gap.
lmk.
thanks in advanced for the input.
Haza
lmk.
Haza
the reason I'm asking is the CAI cause idle surge which causes a rough idle.
Putting some tape over the fog light hole on the passenger's side eliminated that problem.
