SS/TC BAD MPG Thread #2
Do you have the RPD option on your car? If so check your A/F to make sure your car is not stuck in PE mode. That would cause you to get really bad mileage. Either that or a stuck injector or a huge vac leak.
He means that for every 100KM he drives, he burns 11 Liters of gas on average. Not MPG. I think the states and sri lanka are the last ones on the imperial system...
Our boost gauges look kinda dumb though in Kpa..
Suggested causes of my bad MPG
1. I do ALOT of idling, probably 30-60mins a day on average i'd imagine
2. Yes I have a very heavy foot
3. I can't see it being a gas leak, I'd notice the leak in the parking garage at work
4. Boost leak i can't see it being that either, i'd notice that on the throttle and be missing power, as well my boost gauge wouldn't sustain any level of boost under WOT
I THINK that maybe the idling+heavy foot is the answer but JUST incase something else could be wrong I wanted to check.........if I take it to the dealership and they find nothing wrong I'll get charged for the labor and I 100% KNOW i cannot afford hours of labor from a GM shop at over $100/hour.
zero CEL's to date, DIC? Honestly, IMO, if something was wrong I figure i'd notice less power but to me it feels like it's all there........in some senses i hope something is wrong and i can get warranty, but in another sense I rly hope NOTHING is wrong because nobody wants problems with a brand new car.
Last edited by 1WhiteSSTC; Jan 15, 2009 at 04:38 PM. Reason: Automerged Doublepost
no dood, the car has the ability to switch to MPG and i did so to watch the MPG and be able to get more responses/help.
Dude, if you are idling 30-60 min a day that is an extra couple gallons burned and no distance traveled. That and your heavy foot and cold weather could produce some pretty bad gas milage. What is you milage reading when cruising at 60 mph(99km/hr) on flat ground? If it is anything less than 32-34 mpg you may have a problem, but IDK.
well the DIC is still logging under 300km a tank........it could be from my idling tryin to stay warm when it's below freezing temps in combo with my heavy foot but.........i dunno, i still wanna say something seems wrong.
Last edited by 1WhiteSSTC; Jan 15, 2009 at 04:55 PM. Reason: Automerged Doublepost
Log your miles/kms via the Trip Odometer, when you fill up, log how much fuel you put in and do the calculation manually. There have been issues with the fuel calculations before. I've had mine tell me I only got 17mpg before or that I only have 150 miles on a full tank.
As in calculated fuel range?
i haven't made the calculations entirely, i just can roughly tell that under 300km per tank is not good but we'll see how it goes as it gets warmer outside.
11 mpg's is either a mistake in calculations or you have a serious problem....
when I go lapping on the road course and I'm WOT as much as possible I get 8 MPG....
and I know your 11mpg is not while lapping....
take it to the dealer and let them fix it....that's what warranty is for
