start up performance
Old Jan 27, 2009 | 04:51 PM
cobaltssoverbooster's Avatar
does anyone else have a problem when you start up and drive away without letting it get warm it runs like **** and bucks your brains out??
mine has to sit for like 2 min then its good haha
Old Jan 27, 2009 | 04:52 PM
dman090's Avatar
sometimes when i let it warm up and the firs time i put it in drive it will act real sluggish but after the 2nd push on hte gas it will act better
Old Jan 27, 2009 | 04:59 PM
MaxVQ35DE's Avatar
yea its done this to me a couple times, maybe we need to let it finish its 1 minute cold start sequence
Old Jan 27, 2009 | 05:27 PM
orbalt08's Avatar
I always wait for the vacuum to drop to 20 and the rpms to drop around 1,000. She seems to be fine after that.
Old Jan 27, 2009 | 05:39 PM
krispy's Avatar
Only time I get 'bucking' is at low speed in 1st gear (parking lot speed) where sometimes a resonance sets up between the engine and suspension when holding the gas in the same position.
Old Jan 27, 2009 | 05:43 PM
few im not the only one good, ima gonna let it finish its little cycle from now on
Old Jan 27, 2009 | 06:05 PM
platinumrims's Avatar
might i suggest compustar remote start/alarm
that's what i'm getting... supposed to be the best you can buy, my brother inlaw got one for his GT-R. course i'm not sure if the lower end remote systems come with remote start. i know mine does. i know they start at like 300ish as far as price. but it's worth it.
the one i'm getting has a 6000 foot range. ballin.
here's a link www.compustar.com
i'm getting the Pro 2WSSR remote. it's like a little less than 850 after tax and that includes installation... life time warranty on installation, and i think a 3 year warranty on the remote or soemthing and that 850 inclues a 75-100 dollar bypass system so you don't have to run it thru the computer in the car. not bad. plus i wanna know when someone doors my car. make them bitches pay for it... tells you all that stuff on the remote. gonna be halarious when someone hits it in the school parking log and my remote starts beeping and vibrating in class... tells you what side they hit and everything. and you can make it to were the alarm doesn't sound so they don't drive off. make sure they give me 100 to fix the paint lol. and buy me dinner, or it's a hit and run felony. jerks.
you'd have to read up on all the cool **** they do... and there is a cold start setting on it too. if the temp in the car is a certain degree it automatically does it i think.
steven6870's Avatar
Yeh it happened to me once, like my first week, right when I hit second the fuel, seemed like it completely shut off.
My best advice it let it warm until your RPM's drop to right under 1k. I usually let my warm up until coolant temp is around 130, and dont apply full boost until coolant temp is around 160, and even though its more than likely not needed considering the cool down rate of our "small" turbos, I let it cool down for about a minute before I shut it off.
Old Jan 27, 2009 | 06:54 PM
rat's Avatar
rat
There is a reason gm didn't put remote start on this vehicle from the factory. Manual transmissions are not a good idea to be putting remote start on. You should be leaving your car in gear when you park it, and this is the main reason why remote start isn't a good idea on a manual trans car.
Old Jan 27, 2009 | 07:32 PM
uh. the car won't start if its in gear. this is one of the few systems that actually work right. you have to have it in neutral and the prking break on. the remote has an icon that tells you when you can use the remote start feature.t there is a certain way you activate i. it's fool proof. before you turn it off if im not mistakin, you have to leave your foot on the break. put the car in neutral and have the parking break on before your remote will allow you to start the car...
if the car is in gear or you don't do it in a certain sequence the remote won't give you the option to start the car
Last edited by platinumrims; Jan 27, 2009 at 07:32 PM. Reason: Automerged Doublepost
Old Jan 27, 2009 | 07:33 PM
kenhebe's Avatar
I never leave until my water temps hit 100 degrees and I have never had a problem. The same rule applies to my 5.0 mustang
Old Jan 27, 2009 | 08:49 PM
JPizzle's Avatar
Oh yea. Happens to mine all the time.
Old Jan 27, 2009 | 09:06 PM
yobrigidey's Avatar
Exactly what I do.
That sounds like a great plan...leave the car in neutral and rely only on the amazing cobalt e-brake to hold the car from rolling.
Old Jan 27, 2009 | 09:08 PM
boostedss26's Avatar
mine and my wifes car does that. simple fix let it warm up
Old Jan 27, 2009 | 09:17 PM
... what's wrong with the e-brake??
it's not going to magically come lose or something. if it works when you pull it, it will keep the car from rolling when your not in it... i don't know about yall but i know when i leave for school. i won't have time to let it sit for a minute or two. lol. i sleep to late for that pshh. ha. so i'll start it a minute or two before i leave. It's not really that good to run ur engine right after you crank the car anyway. like start and go. plus it's sucks ur gas down.
plus when it's cold outside i want that hoe to be warm when i get in it
freeze my grapes off. lmao
Last edited by platinumrims; Jan 27, 2009 at 09:17 PM. Reason: Automerged Doublepost
Old Jan 27, 2009 | 09:20 PM
in winter my car warms up 10 mins before i drive em. Eventhough it is a winterbeater i still let it warm up.
Old Jan 27, 2009 | 09:49 PM
it's winter down here now and it was like 75 yesterday. MS gulfcoast.
it's friggin hot down here i hate the weather. hot and muggy.
Old Jan 27, 2009 | 09:57 PM
08turboss's Avatar
Mines done it a few times. Twice its turned the check engine light on and set a misfire code
Old Jan 27, 2009 | 10:34 PM
tomj77's Avatar
does it to me all the time in -30 lol unless i let it run for a few minutes or go to 2nd gear quickly
Old Jan 27, 2009 | 10:38 PM
Bika's Avatar
Fail Less.
yup. every SS ive seen does this. wideband goes lean as **** and it starts to buck. if i have to drive it cold, i just ease on hte throttle ever so lightly and let it go if it starts to lean out.
Old Jan 27, 2009 | 10:40 PM
kling1022's Avatar
yep I have it too. It feels like you are getting rear ended haha. Oh and about the e-brake they suck. This has already been discussed
Old Jan 27, 2009 | 10:45 PM
where?
Bika's Avatar
Fail Less.
and yes the car will start when its in gear. a few times i have left it in gear and also put the ebrake on, it starts and i forget its in gear and i let out the clutch, stalling it. I only resort to leaving it in gear when i have to park on a steep slope. otherwise i just jack teh Ebrake. sometimes it takes a lil more force to make it stay but it works good enough.
Old Jan 27, 2009 | 10:51 PM
speaking of ebrake mine is high as a **** when i use it so i had the dealer adjust it and they said its normal what a bunch of lazy mother ******* i had to take it apart and tighten it myself.
