stock dp?
The two cats are the real restriction in the stock downpipe. The next restriction is the crimp which I assume is probably still there. What you have now flows a lot better than stock, but maybe slightly worse than aftermarket.
u dont make any sense. you just said that the restriction is the 2 cats so how is it worse than an aftermarket
What he said makes perfact sense the stock cats do not flow as well as the 3" high flow catted or catless aftermarket DPs. GM also crushes the stock DP down right where the O2 sensor is.
There are three restrictions in the stock downpipe. The major restrictions are the two cats. The remaining restriction is the crimp near the O2 sensor (which I suspect was not replaced). Unless this crimp was replaced with a mandrel bend piece, this DP will still not flow as well as the aftermarket. Maybe I could of worded it better, but the original post basically says the same thing.
