sunroof
sunroof
to all the guys with a sunroof on their tc, does the sunroof close totally flush with the roof of the car or does the back stick up just a little bit past, still being sealed but ya.
Mine's flush at the front, back left & right sides but raised up in the center rear. I think the contour of the glass is wrong. It doesn't match the shape of the roof. No leaks, but wind noise over 80mph. I might see about getting it replaced this spring when I go in for the stage kit.
Mine has been replaced and it is adjusted all the way down and it still sticks up a little, but it is a lot better than the original glass. It was warped pretty bad and it leaked like a crazy at speeds above 45 mph. Now it leaks only if I get close to triple digit speeds.
im gonna go get mine fixed i told em i want it flush, cause every car iv looked at has it flush, so im not gonna except anything less. new car, should be proper.
i think he is right. mine will sit flush if i close it with the door open but then if i close the door with the window up it pops back up due to the air pressure.
That is exactly what mine does but there is really no reason for that because they have the car vented somewhere else to let the excess pressure out.
The sunroof wondow is SUPPOSED to be higher in the back....its supposed to be 2-3mm above the roof in the back and 0-1mm below the roof in the front.
They also dont seal water tight, nothing you can do about that, thats why they have drains..........
Mine does...but no leaks...no wind noise...not touching it...only adjust if you have one of these two problems...
Mine sticks up in the back, but when I looked at a 06 supercharged the other day his was flush all the way around and it looked as if his had different weather stripping than the new ones.
X2. That is how I adjusted mine, it is all the way down, but it still sticks up some and leaks air once in a while at higher speeds.
