surging
Old Mar 28, 2011 | 03:37 PM
bogalusahondakiller's Avatar
surging
Ok since i installed my treadstone parts i get a surging between 10 inches of vacume and 0 psi boost. anyting above or below is fine just in that area it does it. I have looked at everything and everything is right. dont know what to do
Old Mar 28, 2011 | 03:47 PM
CudaJoe's Avatar
Surge?!? Surge wont come from installing charge piping or an Intercooler.. What do you have for a BOV/BPV? are you tuned?
Old Mar 28, 2011 | 05:41 PM
im trifecta tuned and have the stock bpv. i only noticed it after i installed everything on the car. i hear it constantly releasing pressure in that range also. and when it starts doing it the car starts bucking until i either get in the gas or back off of it
Old Mar 28, 2011 | 11:19 PM
Old Mar 28, 2011 | 11:21 PM
vahdyx's Avatar
YouTube a sound clip for us
Old Mar 28, 2011 | 11:49 PM
ill try tomorrow my camera is not the greatest and i dont feel like going across town to get gas at the moment
Old Mar 29, 2011 | 10:25 AM
Treadstone's Avatar
that problem is going to be vacuum line related, LNF's are notorious for being finicky if a vacuum line is out of place.
Old Mar 29, 2011 | 10:26 AM
Treadstone's Avatar
remember you need to bypass the vacuum tank under the intake manifold
Old Mar 29, 2011 | 10:32 AM
CudaJoe's Avatar
so from what Im getting here, you have no bolt ons (other than TRE stuff). and just the Trifecta tuned. somethings up with the tune? Does it make decent power when its working?
What exactly do you have? stock BPV? DID you replace the lower charge pipe?
Old Mar 29, 2011 | 10:37 AM
dthomp2366's Avatar
my car did some weird stuff after I installed the intercooler and all signs pointed to a major boost leak but it was the ECU trying to adjust for it. I just kept driving it around my neighborhood and it "learned" the new part but it sounded like a subi whenever it went into boost and wouldn't boost more than a pound out of vacuum. Oh and the check engine light flashed while it was misfiring.
Keep driving it around without turning it off or letting it die. Should take about a half mile to figure out whats going. My car idled perfectly and reving the engine was normal too when I had my problem. Good luck.
Old Mar 29, 2011 | 11:43 AM
it pulls boost fine. Think im gonna do what treadstone said and bypass the vacume tank. its hard to drive 70 or above at part throttle because it just goes to surging like mad.. but wen it goes into boost pulls fine
Old Mar 29, 2011 | 11:51 AM
ive had all this on for over a month. I dont think its like it should be everyone says how these cars are suppose to be on a tune and im not seeing it.
Old Mar 29, 2011 | 04:37 PM
ok still no difference. i unplugged the sensor that everything goes to and only got 10 psi but no surging. been on the phone with treadstone and we are all stumped. gonna call vince now and see if the car is pulling timing because of the power loss i have from the first time i ran the car till now. this car is driving me crazy
Old Mar 29, 2011 | 08:55 PM
ok i think i've fixed it at the moment. no more flutter. I unplugged the sensor with the car off for about 20 mins while i looked over vacume lines and now its doing fine. Now to see about the other issue im back at again
Old Mar 30, 2011 | 11:37 PM
dthomp2366's Avatar
i did a mod a long time ago that bypassed the vacuum tank like the pontiac has it to eliminate that "ball" the air would vent to. im going to see if I can a take picture of mine. maybe it'll help.
Old Apr 1, 2011 | 12:18 AM
thanks. i was looking at it and if i jut run the vacume line from the intake that you tee into to the sensor it will bypass the tank. i was in a hurrry and when i realized it was good i stopped. i dorve 200 miles and no flutter or anything so hopefully its fixed
Old Apr 1, 2011 | 02:49 AM
RyRidesMotox's Avatar
SO is it all good bro? sounds like a vac line issue for sure. Also if you are still running into issues check the stock BPV diaphragm it could be torn a little bit allowing a leak and some flutter.
Old Apr 1, 2011 | 08:20 PM
yea still good ryan. I'll pull the bpv out when i get home. probably wednesday. i got to go back to work so im chilling in port fourchon right now. send me a message ryan my iphone is in about 20 pieces so i got another phone. this time saving numbers to my sim card lol
Old Apr 1, 2011 | 08:25 PM
DoMiStIc_RuSh_06's Avatar
My car has this issue with the flutter when in vacuum. Let me know what you figure out. Do you have the gms1 sensors?
Old Apr 1, 2011 | 08:34 PM
No i still have stock sensors.. i unplugged the sensor the vacume lines run to. i dont remember what its called. but i unplugged it drove about 5 miles. came home killed the car let it sit for 20 to 30 mins plugged it back up and no more flutter. it could be that sensor going out or something
Old Apr 1, 2011 | 08:36 PM
The bpv solenoid.
Old Apr 1, 2011 | 08:45 PM
I'm definately about to get a bov
Jmc007
Sep 11, 2011 10:16 AM
NJHK
Forced Induction
59
Aug 6, 2009 11:18 PM
jbounce
Aug 29, 2007 09:27 PM
redFLcobalt
May 29, 2007 06:46 PM
sleepercobaltsc
Apr 27, 2007 05:17 PM
