Taintedred07's Blown Motor Future Build Thread
#103
Why not instead of e85 just run e47 with a 5th injector? The combo works great for me and quite a few others, plus I'm only using a little 30lb injector which is plenty of fuel for my setup. Granted I'm of course not pushing nearly the air with my efr that a 6262 will push, but also consider this. You already have the cam with upgraded hpfp lobe which in combination with the bigger DI injectors you already have as well and then add a 5th injector, you should very likely have enough fueling.... as long as the intank pump isn't now your limiting factor. Which it very likely will be.. lol
Just don't rule out e47 my friend. There isn't a ton more power potential or octane in e85 vs e47, aside for the added cooling aspect of the extra alcohol.
#107
Fair point, fair point. Just spitballing here. I was just figuring with the minimal octane difference between e85 and e47 that it would still do well enough to resist detonation. I'm definitely willing to admit if I'm wrong though considering you have first hand experience with testing this turbo. Has e47 with a 93/e85 blend ever been tested with a turbo of that size vs something like e42 (ish) with a c16/e85 blend?
#111
#114
I have been told they out flow the k04 but it doesn't seem rot because that would mean they build more power than the k04 does up top, right? I don't know. I haven't seen a truly successful k04 on lsj before
#118
i dont find 5th injector setups to be a long term solution to fueling issues despite what zzp has done with them
