TC shifting question
Old Nov 21, 2008 | 05:03 PM
BPark86's Avatar
So I don't know when but I think there is now a problem with my no-lift **** feature. When you guys use it, do your RPMs shoot all the way up to the redline or does it stay in place? I coulda swore that they are supposed to stick at the point of ****.
Old Nov 21, 2008 | 05:12 PM
09silverSSS's Avatar
You are supposed to shift right near or at redline using no-lift shift and you have to be really quick doing the shift.
I believe you only have .2 secs. the point of NLS is to hold boost between shifts. You should only hear one pop from the exhaust. Any more than that and you have to shift it faster.
Old Nov 21, 2008 | 05:25 PM
BPark86's Avatar
oh ok, makes sense. i was under the impression that it would hold no matter where i shifted
Old Nov 21, 2008 | 07:32 PM
1WhiteSSTC's Avatar
sadly, alot of ppl out there have gotten that impression, as well, u MUST be in COMP MODE otherwise it doesn't retard the timing properly, DON"T LISTEN TO ANYONE WHO SAYS YES U CAN DO IT OUTSIDE COMP MODE, THEY DUNNO WTF THEIR TALKING ABOUT.
Old Nov 21, 2008 | 07:46 PM
agent007kimball's Avatar
I think you may need to increase your fiber intake.
Haha.
Old Nov 22, 2008 | 12:30 PM
scarface7272's Avatar
Haha.
Old Nov 22, 2008 | 12:43 PM
sport08's Avatar
i have never lifted when ive shitted idk u might wanna see a doc
rat's Avatar
rat
You probably haven't read the owners manual...
Old Nov 22, 2008 | 03:05 PM
40rty's Avatar
SUp guys,
Yo, NLS I got it down pretty good but only from 2, 3, 4. FOr some reason I can never get it for 1to 2. I'm watching the RPM's when I do it, doesn't NLS kick in when you hit 5250 rpm's. By the way, last night when I went out with my crew(Team FullBoost). SPanked a Mustang GT from a dig, Jetta GLI MK5, Nissan 350Z, and some Crossfire. Thank you NLS!
Old Nov 22, 2008 | 04:05 PM
1WhiteSSTC's Avatar
Originally Posted by 40rty
SUp guys,
going from 1st to 2nd on a NLS has proved to be useless, i've managed to do it a few times but I think shifting normally nets better results when going 1st to 2nd.
Old Nov 22, 2008 | 04:42 PM
RBC's Avatar
RBC
don't listen to this guy. j/k
Old Nov 22, 2008 | 06:08 PM
rat's Avatar
rat
Directly from the owners manual:
No-Lift Upshift (SS Models)
If the vehicle has the 2.0L turbo engine and manual
transmission, it has the capability of No-Lift Upshifts.
This feature maximizes vehicle acceleration by allowing
you to shift the transmission to a higher gear without
taking your foot off the accelerator. No-Lift Upshifting
is enabled in all Electronic Stability Control modes.
See Electronic Stability Control (ESC) on page 4-7 for
more information. Use this feature only when the engine
has reached normal operating temperature. Correct
shifting allows the engine to maintain boost pressure
during shifts, while also keeping the engine from
over-revving.
To utilize this feature:
1. Accelerate the vehicle by fully depressing the
accelerator pedal.
2. Just prior to reaching the maximum engine speed,
quickly complete the upshift utilizing the clutch
while keeping the accelerator pedal fully applied.
A quicker shift maneuver gives the best
performance. If the engine is operated at the
maximum engine speed for greater than one
second, the engine exits the No-Lift Upshift mode
and resumes normal engine overspeed protection.
Old Nov 23, 2008 | 01:18 AM
RBC's Avatar
RBC
That you!
As stated above 1 sec. .2 would be REALLY hard by a kick ass driver.
Old Nov 23, 2008 | 01:23 AM
HB_SS/TC's Avatar
no point in NLS in non-comp mode. The traction control will kick in and messes everything up. I tried it already
Old Nov 23, 2008 | 01:32 AM
RBC's Avatar
RBC
I don't seem to have a problem in any mode. I don't think the point is if there is use for it or not, it is if you can do it or not. And once again it is proven that you can.
Old Nov 23, 2008 | 01:49 AM
JPizzle's Avatar
I think I have done it without it in "Comp. Mode", but that was with the TC off, so that helps.
I also think I have done it with the TC on, and I think I shifted a little before the redline that time, but it sure BOGGED, before getting back into it in second gear...
Old Nov 24, 2008 | 06:45 PM
YaKkO's Avatar
Owned
Old Nov 24, 2008 | 06:48 PM
1WhiteSSTC's Avatar
do that twice in a row and your tranny light flashes at you
Originally Posted by YaKkO
Owned
go ahead, shift outside comp mode, enjoy the death of your tranny
Last edited by 1WhiteSSTC; Nov 24, 2008 at 06:48 PM. Reason: Automerged Doublepost
Old Nov 24, 2008 | 10:12 PM
RBC's Avatar
RBC
I did it all day yesterday at the track. You can shift it at 6000 rpms and it will hold there as you shift. I know cause I saw me do it. It didn't just jump to the rev limiter and bounce like you think it will. UNLESS I am just that bad ass at shifting.
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
2009blackSS
Sep 30, 2015 05:57 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
