Tein coilovers for TC
the stance coilovers out right now are really the only ones that will do you any good until you start spending serious money on penske or ohlins coilovers..
if you wanna save money but dont want a real aggressive drop go with pedders springs on your stock struts.
as far as tiens go only 2-3 sets were ever produced and then they abandoened the project
the stance coilovers are the best out for these cars until you wanna spend serious money. and reign...your might be correct in them only releasing one pair im not sure. pedders springs are the ONLY springs for the tc that improve handeling. all others make it worse.
My sportlines felt like btr handling. then slowly got worse. sagging springs
and u dont need a front sway bar. already one there I beleive
If I'm not mistaken...I think Pedders makes coilovers for our cars (in addition to the springs)...I mean their springs are the best for performance currently out for our cars (not a huge drop though)...I can only imagine what their full coilover setup is like...although I believe it's like 1200+ dollars or something.
No, it's 1200 for the whole set hahahahah
and they're nearly identical to the megan and ark systems. Nobody really knows right now how good they are.
and yes Steve, you already have a front sway bar. You also already have a rear one, but the OTTP add on bar improves that.
it felt better because the car was lower. The Eibach spring rates are very close to the stock rates. IT was probably the butt dyno justifying the purchase
That's how it worked with my noodle header...
https://secure.merlinsoftware.com.au...&Level2=COBALT
Haha, it's 1200 for the set.
Pedder Xa Coilover from Pedders
Pedders Xa Coilover from OTTP
I don't know where you're getting your numbers. Don't tell me to do research on suspension.
You have no idea what setup i'm running.
https://secure.merlinsoftware.com.au...rodCode=160058
Teins are amazing no matter what anyone says, sure there are other great springs out there also, but most dont want to spend 400 bucks for springs and xxxx for coilovers. Tein is a great brand with amazing handeling and performance along with a kick ass stance
