testing crank position sensor
Old Mar 18, 2013 | 10:20 AM
GAGNE's Avatar
Exclamation testing crank position sensor
Does anyone no how to test the crank position sensor to see if its bad or good, or are you not able to test them
Old Mar 18, 2013 | 02:29 PM
Stamina's Avatar
The car's computer routinely tests it and pops a code if it is out of certain bounds. As I've found to be the case though, sometimes things manage to go out without causing the computer to catch it.
The sensor is basically just a magnet with electrical wires going to it. As certain teeth on a wheel on the crankshaft pass past the magnet, it creates a voltage, which the computer reads and associates with a crankshaft position.
If you've got a multimeter, you should be able to test for the required resistance, as well as checking voltage as you try turning the engine over.
hacadacalopolis
Oct 28, 2015 06:09 PM
Trav3480
Oct 1, 2015 08:17 PM
Stuff
Oct 1, 2015 05:47 PM
cw383
Sep 30, 2015 12:41 AM
jmelton327
Sep 26, 2015 10:04 PM
