is there any point? (tire)
this might be a dumb/newb question so forgive me.
is there honestly any reason to run wider tires in the back of a FWD car?
im going to run 235/40/R18 in the front
i was debating on the same size or 245/40/R18
only if you're a ricer. the reason why rwd cars have bigger tires in the rear is for traction on the drive wheels.
You could easily run 245 KDW II's
My 225s are too small for the rim...smaller than the Conti's
1 CM.
And a few cars are staggered like so from the factory
The FWD Impala SS and Grand Prix GXP both have larger fronts than rears.
What about grip to keep the rear from coming out in a hard turn? I'm not saying having them bigger than the fronts, but wouldn't that at least be a case to keep them about equal in addition to the ability to rotate your tires?
Edit: Sorry.. missed that one.
of course bigger tires will give more grip. doesn't mean that the rears should be bigger than the fronts.
bigger as in larger then the ones you would put on the front?? then no
larger as in all of them wider then stock but all of them the same?? yes, more contact = more ability to corner at higher speeds
Think in terms of centrifical force. The lighter the weight the less centrifical force. There is more weight concentrated on the front in a FWD car. Less in the rear. Less weight = less centrifical force = smaller tires required if for no other reason less rotating, unsprung weight. The front being heavier and driven would create more centrifical force and lack of traction meaning larger tires. Tires are always a juggling act. Ask any NASCAR crew chief.
Weird cause I actually thought of buying a set of 245 for the FRONT since we need more traction and more weight is on the front axle. Doing the opposite seems kinda wrong.
Anyways If I do anything, I'll put 235s on all corners just to make a little difference if there's any.
don't listen to these idiots..get 275/40/18's for the back 2 wheels and then get like 155/40/18 for the fronts..u'll launch like no 2morrow....everyone else just doesn't know what they're talking about
DANRICKARD
Oct 1, 2015 12:08 AM
