Timing and AFR
Old Jun 9, 2011 | 12:58 AM
TurboJoe's Avatar
Timing and AFR
Hey guys, I was wondering if i could get a sample of what some of you guys are running for both timing and AFR. My tuner set me at i believe 17 degrees give or take and said he felt it was safe on 12.0 afr.
From what i have read, because our cars are DI, they like alittle leaner mix than most cars are used to. What are you running? Seems like i see 12.0-13.0+-. Whats considered overboard?
I am running 93 oct, but the car was tuned on 91 and i am set at 22psi.
Old Jun 9, 2011 | 05:51 AM
Iam Broke's Avatar
A little rich for my blood, but if it'll take 17* on pumpgas I guess that's ok.
.88 lambda or around 12.9 AFR is about the sweet spot. I could never run that much advance until I added ethanol.
Old Jun 9, 2011 | 08:31 AM
Gremlin85's Avatar
I run a .87 Lambda which is about a 12.7-12.8 AFR. I'm currently running 15 degrees of timing up top but I've been able to squeeze 17. I don't feel comfortable with it there yet. I've seen some KR as much as 3.0 from time to time so I cut it back to the 15. With the Meth installed, I hope to be WAY up there
Old Jun 9, 2011 | 08:59 AM
dayhoff35's Avatar
subd to see what all you guys have to say
Old Jun 9, 2011 | 09:07 AM
BartSS's Avatar
im commanded at 12.6 at WOT
Old Jun 9, 2011 | 09:09 AM
Chevycobaltss3's Avatar
My more aggressive pump gas tunes are running. 87 lambda and 18-19 * if you wanna see the tune i will show it lol. I took enough time on these tunes to have 2 kids Hahaha. Im jk but I've been able to run 18-19 of timing as long as the maf fuel trims were a ok..........
Old Jun 11, 2011 | 01:59 AM
TurboJoe's Avatar
Good info fellas, also my first post was miss information. Dont know why i thought i was tuned at 12.o afr and 17*. I am at 12.2x commanded and 14* up top with zero knock. My tuner felt this was more than safe, i feel the same. Next up is an E85 tune. I just wanted to see where you cats were at.
Old Jun 11, 2011 | 02:03 AM
Ch1ck3n's Avatar
I've run 18* up top on Shell V-power with no problem. But 14-15 at what IAB said for AFR is a good spot for 91 and 93
On ethanol.. 26 haha
Old Jun 11, 2011 | 06:05 AM
evil 2.0's Avatar
my car is 12.63 with 14 * at wot
Old Jun 11, 2011 | 09:37 AM
09CobaltSS1's Avatar
I'm on a relatively conservative e47 tune running 22psi, 20* advance, .88lambda (12.9:1)
In general most tuned LNFs will see about 14*-15* at most on pump gas without any knock issues. Anything beyond that can get a little iffy especially when you start incorporating hot humid oxygen depleated summer air.
but like I said though, this is a generalized statement..
For example, this guy's car seems to absolutely love timing somehow..
wow.. 18* on 93? That's some amazing gas you got there man..
Old Jun 11, 2011 | 03:19 PM
silverbullet08's Avatar
.88 AFR and 16* up top is as far as i have pushed it on 93
Old Jun 11, 2011 | 03:44 PM
SOHC24powa's Avatar
I'm not sure about the timing 17* maybe, with .5 kr in the lower to midrange on 93 pump. and the a/f is 11.8-12.0:1, didn't make any more power at 12.8:1 so I figured the extra fuel would help with cylinder temps and keep the tune a bit safer.
Old Jun 11, 2011 | 03:46 PM
skip_jones's Avatar
.88 lambda or 12.93 afr and 17.5 degrees timing up top.
thats on 93 octane. still see some occasional knock up to 3.8 degrees.
Old Jun 11, 2011 | 03:53 PM
wow.. to be honest I'm a little surprised to see people running over 16* on 93 with no serious KR issues. I'm very aware that every car is different especially in different climates but it just strikes me as a recipe for detination. Are you guys assuming there is no KR or are you logging the vehicle yourself and know everything is peachy for yourself?
Old Jun 11, 2011 | 04:00 PM
skip_jones's Avatar
i log mine quite often. i only see kr once in a while. when i do, half of that
is only on 1 cyl. so i figure its probably false knock anyways. its rare that
i get kr and it pulls timing. (it has happened though). worst kr i've ever seen
was 3.8 degrees.
Old Jun 11, 2011 | 04:11 PM
That's pretty damn good man. I know my car definitely didn't like anything over 15*, but there again is just the difference for each vehicle in a different climate. The 3.8* of KR you were seeing could have even been false knock as well. I know I used to have an annoying issue with it last summer (between 2*-4*) that at first I though was actual knock.. long story short, it ended up being false knock which I was able to resolve
Old Jun 11, 2011 | 06:30 PM
SOHC24powa's Avatar
logged it while tuning.
Old Jun 11, 2011 | 06:48 PM
slowstang's Avatar
12.6 afr with 15 degrees of timing. Any more timing on 93 octane and it would knock.
Old Jun 11, 2011 | 06:55 PM
DoMiStIc_RuSh_06's Avatar
What was wrong because I'm having a similar issue.
Old Jun 11, 2011 | 09:16 PM
Ch1ck3n's Avatar
18* was very up top and ramped in smoothly and gently.
It was kind of scary running that much timing, and only on about 17-18 lbs of boost in cool weather for a few weeks.
As for logging, I log every day with VCM scanner.
Old Jun 11, 2011 | 09:41 PM
o0o0o0o0o0ohhhh.. ok that makes alot more sense then. Of course I realize the timing is ramped in and is your peak timing up top but I was assuming you were pushing over 20lbs of boost with that much timing on 93 octane. I seriously couldn't wrap my silly little head around how you safely ran that much timing.. lol I get it now though..
Old Jun 12, 2011 | 10:09 AM
Ch1ck3n's Avatar
Haha yeah, over 20psi, the most I will go on a tune is 15*.
Old Jun 12, 2011 | 06:28 PM
Wangspeed's Avatar
I think it's pretty funny. If you rewind a year in the forum, people were trying to run 20* up top on 93. I said the most I could get was 15* on my tune, and people thought I was doing something wrong.
Even with a max of 15*, I need to splash in some 100 octane when I go to the track, or I start getting knock after a lap or so.
Old Jun 12, 2011 | 06:49 PM
all hail Wangspeed..
are you seeing knock after 1 lap due to high IAT's?
Old Jun 12, 2011 | 07:00 PM
sundevil07's Avatar
Most I could squeeze on 91 with 20 psi was 11* up top. Nowhere has worse gas, now I'm e47 and running 20* up top with no knock.
