Tire pressure light on
Well got in my car and turned it on then i got check tire pressure did and needed air so i filled them up now the warming light on the dash wont go off. Is there a way to reset it or am i missing something
i had the same thing happen to me the other day, i was stuck in some snow and turned off my TCS, then after spinning my tires to get outta the snow my pressure when down and the light came on... so i just went to the gas station to fill em up...
yeah i think 35 is the norm for pressure
does it register any pressure for the tires, if there is no reading for any or even just one tire you may have a messed up tpms. if they are still reading them idk. have you restarted the car since adding air? maybe try to unplug the battery for a couple mins to reset it.
Hell my TPMS was broken like a month after I got the car. I took it back and was like um fix this. They said they had to check if I had swapped the tires and tmps into other wheels... I looked at the service guy and then back at my odometer and laughed. 50 miles on it and swap the tires, RRRIIIIGGGHHHTTT.
the light goes off on anything above 28psi. if it doesnt try relearning it, turn key to on position, press lock and unlock button on remote at the same time till ur horn sounds a 3 times or whatever it is, then inflat or deflat tires starting from front driver side then going to pasengerside front, then passenger side rear, then driver side rear, give each tire about 8 seconds of air (or let out air for about 8 seconds) then stop and wait, horn will beep once, then move to next tire, when u have done all 4 the horn will sound 2 times and they should be relearned, put ur tires to whatever psi u want and see if that doesnt fix it.
DANRICKARD
Oct 1, 2015 12:08 AM
