top speed ecu will see
so discovered something interesting today, did a log late at night nothing on the road, so I decided to see what shes got. I pegged the gauge past 160mph it goes a little past them stops. then I looked at the log and according to the log it goes to 158mph and that's where it stops, the rpms keep climbing but the speed recoded in hptuners stops at 158 and will go no higher. is there some why to make the ecu register more speed or do I just need a gps if I want to see how fast it will go.
Hpt may but the ecu may not. Iv tried twice where I burried the needle rpm keep going up and speed goes up steady to 158 and stops there every time. Even though on the gauge the needle goes past 160. Gps will confirm as soon as I remember to use one lol
Well I just top speed tested it, didn't burry needle like usual due to slight incline I guess. Speedo said 260kph, I guess that's same place on speedo as 160mph, hptuners says 158 mph, gps said 167.7mph or 270kmh, so this cars ecu definitely doesn't read past 158mph
Scanner maximum speed tops out at 158 mph
The new 2.25 scanner can read past 158mph it's just a software limitation of 2.24 scanner. Built Corvette guys going 200mph+ on a dyno had the same complaint.
ThoR294
Oct 4, 2015 08:44 PM
z28addiction
Sep 28, 2015 12:03 AM
