treadstone lower ic pipe
does the treadstone lower ic pipe have the connection for the hose that goes to the boost solinoid or manifold or where ever it goes? or do u have to tap one in urself? pic has just the connecton for the map sensor
I just ordered this pipe. I'll let you know when I get it I didn't even know there was a connection for the boost solenoid. I ordered the direct stock replacement, not the MAF relocate one.
well idk where it goes, i dont really look, but there is a vac hose connected beside the map usually
i need to change out my hahn, that **** rusts
yup it took me around 6 emails to get a response from them over a 3 week period and finally i asked them how much itll cost to have it put in never got a response and finally they said just to call them, there customer service is horrible.
My Treadstone lower ic pipe didn't have a vac line going to it. i didn't think any (including stock) of the lower ic pipes had a line go to it.
btw, Treadstones customer service is actually top notch...but you need to call them. its wayyyyy quicker. emails usually take a few days but calls are instant. they will do anything to make sure you are satisfied.
ya i dont wanna risk wrecking the paint job or screwing it up and it just being a paper weight because something that should be there isnt. im gonna tell them to add one if i decide to buy one, wish they would just add it seeing it should be there
Well for people that don't need one its not an issue. Besides its not that hard to just relocate it anyways....
Top line coming out of the solenoid is supposed to go to the lower CP... You need to connect it to a boost pressurized area, like the manifold there... the line from the intake manifold goes to the vacuum tank so you just splice it in there and your done.
