Trifecta 23 psi tune?
Yeah im gonna have a fun time considering my next day off is sunday then tuesday
Vince seems to think my ecm may be holding it back
I dont mind coming down by arundel mills mike
He knows theyre stock. He said they were good to 27psi
ok i need to stop u right there, and i want everyone to stop giving this advice cause its not true. what ur saying only happens on stock tune, it does not happen on trifecta or any other after market tune because learn down is gone. my car is tuned for 22 psi and it hits 22 psi no matter what the weather is like. on stock on the other hand is a different story. trifecta tune does not tune u to hit a certain horse power like stock gm tune does, so please, please stop telling people they boost less cause its colder. thank u.
Work itself out? Is that something that can be done that way?
Oh wait should i unplug my battery
no. i ran mine down the track at a test and tune day after about 4 runs it started to get the fuel pump up to par. the map is set out right the pump on the cam on the other hand has to be worked at its turned on anf off to make the pressure it drops off causeing the low boost. as my master tech at work explained to me.
its 20 here
vince is insisting that the ecm is doin something funky to control it and he's going to trick my iat's to get it to raise boost
im not sure if you can go to a shop i just know someone that makes them and sells them here in AZ and its pretty simple to do it
you dont have to use soap and water if its quiet enough you would probably hear it
YouTube - boost leak test
