trifecta dyno numbers
Just got the car off the rollers today and my numbers were all around 303 whp 362 wtq
those being the highest .... mods being intake downpipe and trifecta 22lb tune are these numbers correct torqu seems high
wow, those are very high numbers for a low trifecta tune with 2 bolt-ons...good for you..i was thinking you should be around 290whp and 320wtq
Sounds right to me. I have the same mods and put up pretty much the exact same numbers (only three digits off on each).
On a Dynojet dyno with K&N SRI, Catless DP and Trifecta 22psi tune I made 300 hp and 359 tq. My sheet's in the dyno thread. I just put it there a couple of days ago.
wow, most people with ay trifecta tune do ot have over 350wtq even with the 25psi tune, but great numbers for you guys with a lower boost tune and 2 mods...curious to see what the power curve is though...
the intercooler allows you to raise the timing in a custom tune, therefore allowing more power and does cool better if you are in a climate like mine...plus its waaaaay better quality then stock..my zzp weighed 31lbs, and the stock one weighs like 6 because its plastic.
if i could do it all over, my performance mod list would be
1. zzp catless downpipe
2. k&n intake and forge bpv
3. injen charge-pipes with mpx upgraded couplers
4. zzp intercooler
5. zzp stage 4/ or ky stage 3 clutch
6. then get an aggressive hp tune
4. zzp intercooler
