Trifecta infiniboost
Old Sep 15, 2010 | 12:47 PM
paintballerr78's Avatar
I was going to get the infiniboost with trifecta and i heard sometimes the car can be put into limp mode and will cause troubles with the car. Will i have any problems boosting 25-27 on a stock 2010 ss/tc
Old Sep 15, 2010 | 12:52 PM
Gunney_07's Avatar
get some bolt-ons and 23 psi tune..... your car will not like like 25psi + for very long. (without meth)
Old Sep 15, 2010 | 12:54 PM
redstarpa69's Avatar
Drove a 09 TC Sedan with infinibooooost..super sweet only one problem you must have supporting mods to do it right.. if not, you'll def break something and it will cost a boat load to fix it...
Old Sep 15, 2010 | 12:56 PM
davebetterthanu's Avatar
Just stick with 21-23 psi
I'm at 20-21 myself
right now i have dejon hotside piping and tial bov. Im buyin a MPx catless downpipe and going to get a new intake. If i did choose to run the inifiniboost what else would i need for the car. I might just run the 23psi tune. Also if i get the tune so i have the catless downpipe code deleted and i dont have teh downpipe yet will it mess with the car at all
Old Sep 15, 2010 | 12:57 PM
Gunney_07's Avatar
don't run any thing above 24psi with out meth
Old Sep 15, 2010 | 01:10 PM
alright ill just get the normal tune so will it matter if i say im running a catless downpipe and dont get it in time will the car run weird without a catless dp then?
Old Sep 15, 2010 | 01:15 PM
BYT*SS*TURBO's Avatar
Don't run anything above 24psi without pistons/rings is what you meant
A Gm Tech came on and stated the stock equipment will score the cylinder walls from the rings expanding over 24psi of boost. Most people now stay below that number LOL!
Old Sep 15, 2010 | 01:16 PM
Gunney_07's Avatar
it shouldn't really effect drive-ability, but why not just wait get bolt-ons done and then tune. That way your not retuning it all the time.
Old Sep 15, 2010 | 01:26 PM
cause im buying the cable or tuner in like 2 days so i can just email vince and get my tunes then so it wont be a problem at all plus im not gettin a intake for awhile
Old Sep 15, 2010 | 01:57 PM
ItalianJoe1's Avatar
I've rebuilt one LNF that was taken out by an infiniboost tune. It's too much for the stock turbo. Piston came apart, ate up a sleeve.
Old Sep 15, 2010 | 03:49 PM
ecotecturbo's Avatar
You will have a blown engine if you get infiboost, end of story!
Old Sep 15, 2010 | 03:57 PM
julius41282's Avatar
Trifecta Selectable Tune will be your best bet. And like everyone else said, there is NO reason to run more than 24psi on the stock turbo...you may spike higher than 24psi, but I believe that's normal.
Old Sep 15, 2010 | 04:04 PM
09whteSSpssssh's Avatar
Course you have me over it so you can blow me up! But my car resists you so far.
Old Sep 15, 2010 | 04:16 PM
drewbroo's Avatar
Some good info and some ignorant statements in here. I have been running the "infiniboost" tune for 20K miles. My engine is not blown, and it runs better than ever. Most of the time blown engines come from factors other than tuning. (The setup/gas/bad installs/water/redneck mechanical engineering + improper tuning)
The infiniboost tune does not mean "above a certain PSI." It just means the learn down has been moved to an unreachable level, so vince can tune your car to make it as fast as possible.
***Fixed
Old Sep 15, 2010 | 04:58 PM
Cavalierssr's Avatar
Originally Posted by drewbroo
Some good info and some ignorant statements in here. I have been running the "infiniboost" tune for 20K miles. My engine is now blown, and it runs better than ever. Most of the time blown engines come from factors other than tuning. (The setup/gas/bad installs/water/redneck mechanical engineering + improper tuning)
I think you meant to to put "NOT" blown. Don't jinx yourself
No problems here with my engine. *knocks on wood*
Old Sep 15, 2010 | 05:15 PM
I ran 30psi thru my own car for 10k miles with no ill effects from it. Im just repeating what a GM Tech wrote.
I have seen a big difference going from 22 to 24psi but very minimal going above 25psi!
Old Sep 15, 2010 | 05:29 PM
does anybody know how much a reseller of tunes pays for a tune i was looking into buying the cable for my tune and i know thats 200 plus the tune and im wondering how much the tune would cost
Old Sep 15, 2010 | 05:38 PM
drewbroo's Avatar
Ask Vince
Fixed it (:
ya i emailed him just waiting to see how much it would cost cause i can get the cable for 150 so if the tune is relatively cheap ill get both so i can always adjust my car and tune other peoples
Old Sep 15, 2010 | 05:51 PM
Ferretts's Avatar
it feels expensive to be the guinea pig
Old Sep 15, 2010 | 06:46 PM
SSlobalt's Avatar
Most drivers aren't running any extended 4th gear pulls. If it's tuned right and you don't run out 4th gear at WOT, I'd say your motor will last a long time with an infiniboost toon.
Old Sep 15, 2010 | 06:52 PM
Iam Broke's Avatar
Prob $200 - 250 depending on the tuner. IDK what Vince charges direct. Mine was an upgrade from over a year ago.
Old Sep 15, 2010 | 06:53 PM
SSlobalt's Avatar
Probably $320
Old Sep 15, 2010 | 08:43 PM
FRSTGRDEDROPOUT's Avatar
High boost will not cause piston rings to expand. Heat will. Now with 24 psi your gonna get highter combustion temperature. And the gms1 tune puts the car to 22 psi, i doubt gm would set the boost so close to a boost level that could cause catastrophic failures. I've seen guys blow the plastic side tanks of their stock IC at around 25 psi.
