trifecta tuned ???
Old Aug 18, 2009 | 12:55 PM
Black_Turbo_SS's Avatar
trifecta tuned ???
ok so i have my car tuned with the trifecta stage 2. mods are : tune, 3'' exhaust with no muffler, 3''catless dp, dejon SRI, and dejon BPV. So when im going through gears at WOT my boost spikes at like 25psi then falls to about 22psi. but if im cruising in 4th and downshift to 3rd then go to WOT it spikes at about 29-30 psi and falls down to about 22psi by the time i shift. Does anyone see a major problem here? im kinda iffy about the boost. but it mostly only spikes 30 psi if im at a low rpm in 3rd then go WOT.. any ideas guys??
Old Aug 18, 2009 | 12:58 PM
Terminator2's Avatar
Put your stock airbox back on and see what happens. Normally the spikes are caused by really rich A/F mixture when you have an intake and your STFTs and LTFTs are not in check.
Old Aug 18, 2009 | 01:04 PM
yea thats something i will have to try. i think the trifecta tunes run rich regardless bc of how the timing is changed. right? atleast thats what ive heard from others.
Old Aug 18, 2009 | 01:10 PM
Actually most of Vince's tunes do not add that much timing. I dunno why he runs that rich of an A/F on these cars.
Old Aug 18, 2009 | 01:15 PM
julius41282's Avatar
I noticed my boost spiking as well, but only to about 25 on a WOT pull. I have been monitoring my A/F ratio's as well and they seem to be holding in in the 13's and 14's. Which I think is pretty good...but I could be wrong.
Old Aug 18, 2009 | 01:27 PM
i have no idea what my AFR's are. i was thinking about hooking my friends superchips to the car and see if it will let me read my AFR's that way.
Old Aug 18, 2009 | 03:38 PM
glhs379's Avatar
my trifecta tune stays dead on at 24 psi
vince has me at 6 degrees of advance over stock, and no knock at all
runs like a rape ape, leaps and bounds over my ppc tuner
Old Aug 18, 2009 | 03:41 PM
Projekt's Avatar
id have to say a safty issue.
if you start running leaning you have the risk of running very lean and causing knock..could ultimatly damage a clients car.
As for this..ether your map sensor is pooped.
or your running infiniboost.
mine does the same thing...it could be your intake also.
Old Aug 18, 2009 | 03:51 PM
These cars rich knock a lot more than most realize. I know because the person who tuned my car originally was running rich and on the street when I logged it for the first time it was pulling 8-10* of timing whan only 8-12* of advance was commanded.
Old Aug 18, 2009 | 03:52 PM
Projekt's Avatar
hmm odd. i seriously need to get a scan gauge of some kind to start monitoring this.
Old Aug 18, 2009 | 03:57 PM
I am not sure Vince is running them as rich now as the last dyno I saw had the A/F in the 13s and 12s with the richest being 12.4. IMHO the best and safest A/F is 12.6 to 12.8 in this car.
Old Aug 18, 2009 | 03:59 PM
Projekt's Avatar
i dyno on saturday..we will see!
is there a way for me to get around the launch control deal on a dyno? i heard this could be a issue
Old Aug 18, 2009 | 04:03 PM
Not if the trigger for the tune is comp mode. Should be ESC off IMHO.
Old Aug 18, 2009 | 04:06 PM
Projekt's Avatar
my trigger is comp mode.
Old Aug 18, 2009 | 04:09 PM
blownss06's Avatar
You have to dyno in ESC off. Just dynoed the other week and it will hit that launch control rev limit at 5000. The tune should be there in esc off as well try it sometime.
Old Aug 18, 2009 | 04:10 PM
Projekt's Avatar
esc off is holding down the traction control button correct?
Old Aug 18, 2009 | 04:11 PM
Launch control is going to engage because the rear tires are not spinning. Maybe you can pull the fuse for the ESC. I am not sure if you are going to be able to dyno that way.
Old Aug 18, 2009 | 04:14 PM
blownss06's Avatar
Right just hold the traction button for 10 sec and it will shut everything off.
Old Aug 18, 2009 | 04:19 PM
Projekt's Avatar
okay, vince just told me that one to. good to know.
Old Aug 18, 2009 | 04:25 PM
Yes, you have to hold it for about 7 seconds.
Old Aug 18, 2009 | 04:26 PM
blownss06's Avatar
hey term, i got some retros for sale right now. Take a look.
Old Aug 18, 2009 | 04:33 PM
where?
Old Aug 18, 2009 | 04:38 PM
blownss06's Avatar
https://www.cobaltss.net/forums/parts-66/fs-black-retrofits-185329/
Old Aug 18, 2009 | 04:51 PM
Hmm I have my tune set to tun off and on with cruise control
Old Aug 18, 2009 | 04:57 PM
blownss06's Avatar
Then it probably doesnt matter if you have esc off or not just as long as you have the cruise control on.
