Trunk mount meth kits
Old Apr 3, 2011 | 12:45 AM
D-mac's Avatar
Let see some pics of Trunk mount meth kits
Going to install my AIS Stage 1 soon and would like to see some installs
Going to try and fit under spare tire cover
Old Apr 3, 2011 | 01:06 AM
OntarioKev's Avatar
I have the first gen AIS kit mounted where the spare tire used to be in my 07.
If I feel ambitious, I will take a pic for you.
Kevin
Old Apr 3, 2011 | 01:11 AM
CobaltSC06's Avatar
Old Apr 3, 2011 | 01:12 AM
tomj77's Avatar
i mounted my snow kit just to the right of the spare tire cover. did the plumbing today. went pretty good. will take pics sometime
Old Apr 3, 2011 | 01:27 AM
cobaltsssc760's Avatar
http://i1092.photobucket.com/albums/...c760/trunk.jpg
http://i1092.photobucket.com/albums/...760/trunk2.jpg
Last edited by cobaltsssc760; Apr 3, 2011 at 01:28 AM. Reason: Automerged Doublepost
Old Apr 3, 2011 | 01:30 AM
CobaltSC06's Avatar
Love your trunk setup, clean and hidden. Props to you!
Old Apr 3, 2011 | 05:35 AM
Gunney_07's Avatar
my setup is not as pretty as his --^,but just as functional lol.
Old Apr 3, 2011 | 07:11 AM
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
Old Apr 3, 2011 | 11:45 AM
D-mac's Avatar
Mine will also be the First Gen AIS Stage 1
Going to test fit it under spare tire cover today
Did you make a mounting plate?
I need to swap nozzles i think i got a 10 gph one AI10 it says
Emailed AIS but didnt get an answer this week can i use any companies nozzle? Thinking 5 gph would be lots
Old Apr 3, 2011 | 11:48 AM
Gunney_07's Avatar
yeah 10 gph is too big, start with a 3gph the move to the 5gph if every thing checks out.
Old Apr 3, 2011 | 11:50 AM
Gunney_07's Avatar
also what psi pump do you have, that makes a big difference?
Old Apr 3, 2011 | 02:34 PM
i think this is the second post you said the same thing... but yes just as functional. i was gonna mount my tank in the spare tire but i had a cryo2 co2 tank that sat on the left side but it was thrown in the trash by a family member while i was on vacation.
Old Apr 3, 2011 | 02:39 PM
pump psi should be around 150psi
Old Apr 3, 2011 | 02:46 PM
Gunney_07's Avatar
lol yes it is, i copied and pasted it out of the other thread
also there is generally 3 psi settings. 150,220,250 and the gph rating on the nozzles changes when under different pressures.
Old Apr 3, 2011 | 02:50 PM
ha. i wouldnt get a pump over 150 depending what tubing your using to hook it up.
<tylerjclance> that setup doesnt stress your pump having to draw out of the tank straight up like that?
Old Apr 3, 2011 | 03:01 PM
Gunney_07's Avatar
my pump from Devils Owns is adjustable from 150-250, This vendor in particular only sells one type of nylon line that is rated for 350 psi operating, and 1400psi bursting.
Nylon Tubing Devilsown
Old Apr 3, 2011 | 03:07 PM
carstedt's Avatar
i jus have the tank mounted in the back and my pump is up front...and i have my pump up in the engine bay and it doesnt stress it out so i dont think his set up should either but who knows
Old Apr 4, 2011 | 09:21 PM
Originally Posted by tylerjclance
the way the pump is drawing from the tank straight up like that cant be good for pump
Old Apr 4, 2011 | 09:28 PM
EXsoccer1921's Avatar
i never used my trunk so i just mounted it for ease of filling.
activation light i had wired up. you can see it in this video skip to about 2:15
YouTube - 13.88@104
Old Apr 4, 2011 | 09:44 PM
Ting-ting's Avatar
YouTube - 13.88@104
sounded good
Old Apr 5, 2011 | 12:24 PM
gone_in_10_sec's Avatar
See some of you guys have your meth pumps/tank mounted in the trunk, was it by choice or design?
Old Apr 5, 2011 | 12:34 PM
Gunney_07's Avatar
choice
Old Apr 5, 2011 | 12:38 PM
It is perfectly fine. THe pump works in any direction, upside down sideways, upright. According to devil's own, it was just easier to mount upside down :p
Old Apr 5, 2011 | 09:08 PM
D-mac's Avatar
I bought this AIS kit stage 1 with the 1.5 gal tank from someone never used apparently
What i got is 25 Feet of Tubing, Pump mounted to Tank, Switch with 3 electrical posts and one hose fitting and my Nozzle and 90 degree adapter
Anyone have a good install instruction for such a kit?
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 04:49 PM
OrangeCoba
Oct 1, 2015 10:00 PM
yellow dragon
Sep 28, 2015 09:49 PM
Sep 27, 2015 08:53 PM
