Originally Posted by 1badBlueberrySC
(Post 4265399)
Yes, I am running his tune now! :D 20* of timing is fun!
i have like 3 degree of timing lol. i need some retuneage. lol.
Originally Posted by Raven SS
(Post 4264010)
i knew he was a scam....jumped around the states stealing peoples money then rolled.....if he couldnt tune a lsj what made him any better with a lnf? tuning doesnt change between the engine...its all the same artform....everyone should have waited for bryan to get his hands on a car lol
Originally Posted by Terminator2
(Post 4265449)
I did that too but did not seem to make any difference over 17* I dunno.
But I could deff. tell a difference between the 17* tune map and this one at 20* I did however do my own little touches here and there.... to make it a bit more MY car specific! :D |
it's not the peak timing that makes the power. if you compare that map to something else, you will notice a lot of timing work in different area's/
reign. wtf is goin on with your car? |
(Post 4263418)
All of stevos tune suck they knock like crazy. I tuned PrincessTurbo's car stevo had him running 7* of timing and 0.83 Lambda and it was still knocking 2-3*. I have him at 0.88 lambda and 14* on 91 octane with no knock at all.
Before it sounded like rocks in my hood . Now it sounds smooth and acceleration feels A LOT better .. If you compare the two tunes you will see they are entirely different .. It seems that the Stevo tune is just modified to be a dyno queen and terms tune uses the base tune but extends off of that with fine adjustments . Much better and I can tell the engine likes me a lot better to .. No more almost stalling getting out of first gear .. just the little shit that makes it better .. Now I haven't dynoed either of the tunes but if its breaking traction and no knock less popping and I am beating cars I used to run neck and neck with .. But I am also running more mods Still need an Intake I been waiting 7 weeks for a CAI from CIA .. Facotry airbox mod WHAT ?:lol: |
Originally Posted by reign1
(Post 4265663)
Originally Posted by Area47
(Post 4265903)
(Post 4264010)
I was kidding bout the timing Area. Im not positive on what the timing is actually.
im dats logging and sending to u tonight., |
why can't any of you be loacted here in canada :(
"Apparently" the great "PSYCHO" was in boot camp or something....
And is back again.... so we will see a whole new SLEW of fucked up tunes here shortly! |
(Post 4268327)
Originally Posted by jmiller15
(Post 4268312)
(Post 4268497)
I doubt it really. Most of the cars that were tuned by him the first place have my tune, yours or Areas now.
LULZ!!!! hahahahahar thats by no means bagging on term area or blue....just to make that clear |
I dont think psyko tunes will be showing up.
hes married. in the military, and just living. i dont think he is tuning anymore. but to each their own. My car is doing much btr now. thanks you guys. data logs are going to you area tonight. |
Another tune I did
http://forums.backyardturbo.com/pict...&pictureid=424 A lil hard to see, I will upload a better screenshot but 35.33 maf lbs. :) |
thatd be me (retune for Air box) .... BYT (nick) is a GREAT tuner ... very helpful and knowledgeable to boot!
http://i27.tinypic.com/2ceg1f7.jpg |
yes but only 26lbs VE airflow.... C'mon you can do better than that.... :D
At that one spot...yes lol
Once you get that up in and around 30 then we can talk! :D :D
But looks good... it's a little rich for only 17*... lean it up a bit ( I was able to pull 17* and .88 lambda with no knock) |
Care to post a screen shot then blueberry??
The car was knocking with less timing and .87. I richened up slightly and was able to run a bit more timing. The car pulls like mad and he is quite happy with it :)
If you look at the 1st gear portion, it is over 30lbs ve |
Well DUH it's first gear... ha ha ha
Most of my logs show an average of 29.12 lb/ VE (which is your TRUE airflow) THe MAF lb/mn can be skewed to much |
(Post 4277596)
