upgrade turbo balts come in!
Old Dec 9, 2009 | 02:52 PM
cardelino18's Avatar
ok questions!!!!
1) whats your WHP/WTQ??
2) What kit is it?
3)supporting mods?
4) WHO TUNED IT?
5) Which clutch are you running?
Thanks!!!
Old Dec 9, 2009 | 07:43 PM
tomj77's Avatar
300-315 whp, maybe 350wtq, never dynoed
trifecta select a tune at 21 psi for now
stock clutch, no slipping at all. 4 months on tune.
Old Dec 9, 2009 | 11:57 PM
spinall4's Avatar
He said upgraded turbos, not tuned...
Old Dec 10, 2009 | 05:15 AM
mkriebs's Avatar
Aye. Keep this in mind come spring.
Old Dec 10, 2009 | 06:32 PM
tomj77's Avatar
oh read it wrong sorry
Old Dec 15, 2009 | 08:46 AM
firerat's Avatar
Bump for actual usable info please!
Old Dec 15, 2009 | 08:59 AM
ericgt79's Avatar
Old Dec 15, 2009 | 12:45 PM
silverbullet08's Avatar
2) What kit is it?
3)supporting mods?
4) WHO TUNED IT?
1) 320-340hp/380-400wtq
2) Not a kit. Few bolt ons
3) Charge piping, custom CAI, Catless DP, 3"catback
4) SUPERMAN
5) Stock w/ NO problems
Old Dec 15, 2009 | 12:47 PM
pookie025's Avatar
wow these ppl are retarted
mkriebs's Avatar
Thats not a big turbo.
IDK whats so hard about to understand in this thread. AFAIK, there are about 2 big turbo swapped balts. EcoTechnik, and Bad balt.
Old Dec 15, 2009 | 12:51 PM
cobaltltblue's Avatar
I'm going to do a swap after taxes, so i'll be back.....
Old Dec 15, 2009 | 12:53 PM
Terminator2's Avatar
2) What kit is it?
3)supporting mods?
4) WHO TUNED IT?
4) SUPERMAN
If your on the stock clutch and have no issues your car is not really at those power levels or you have a very generous dyno out there. Mine slips a lot in 3rd and 4th and sometimes in 2nd if the tires decide to hook up.
Old Dec 15, 2009 | 12:54 PM
mkriebs's Avatar
+1 billion
Old Dec 15, 2009 | 01:46 PM
20redline's Avatar
my clutch use to slip when i had stock tires but then i bought nittos 555r 245 40 18 for the front and now no slip, but then again im only at 332whp and 376wtq
Old Dec 15, 2009 | 01:56 PM
That makes no sense. Drag radials increase traction thereby putting a lot more strain on the driveline including the clutch. Stickier tires mean more clutch slip not less.
Old Dec 15, 2009 | 02:04 PM
20redline's Avatar
idk im just saying when i put the pill mod my clutch would slip its butt off like you said especially in third gear but now that i bought these tires no spin on tires and no clutch slip. maybe i just thought my clutch was slipping and it was just my tires spinning it ass off.
Old Dec 15, 2009 | 02:07 PM
Maybe but there is a big difference. When the clutch slips the RPMs go up quickly but speedometer does not move as quickly. Tire spin the tach and speedo jump up at the same rate.
Old Dec 15, 2009 | 02:57 PM
boostking's Avatar
Originally Posted by cardelino18
ok questions!!!!
2) What kit is it?
3)supporting mods?
4) WHO TUNED IT?
Thanks!!!
1)410whp/395wtq 20-22psi (low boost)
2)Dejon Power House 5457rb turbo kit
3)intercooler and pipping, downpipe (no cat), sri
4) MEEEEEEEEEEEEEEEEEEEEEE
5) Stock clutch but had spec stage 3+ ready to go in....
Old Dec 15, 2009 | 03:23 PM
pt5457balt's Avatar
1. Don't know
2. dejon 5457bb kit
3. hahn intercooler, dejon intake, synaps catless dp, mandrelbenexhaust 3' with 6 round magnaflow
4. Trifecta
5. Will be running spec 2+, after rebuilding from number# piston giving way
(no, i do not believe it was the tune that did it. I ran it for awhile with the pcv and valve cover vent tubing disconnected for awhile, which i think may have caused the rings to go bad, which i'm attributing to misfires/detonation causing #3 to go out)
Old Dec 16, 2009 | 02:08 AM
09BlueBaltSS's Avatar
Da troof
Old Dec 16, 2009 | 01:05 PM
buckyboy56's Avatar
305 hp/ 338ft. tq
just a tune
Tuned by No limit Motorsports
stock clutch and now it slips in 4th and 5th gear from low revs.
I have the clear image high flow cat and boost tubing but haven't dyno'd it yet.
Old Dec 16, 2009 | 02:34 PM
mkriebs's Avatar
I need to quit watching this thread before I have a coronary on some of these idiots.
Old Dec 16, 2009 | 02:37 PM
ecotecturbo's Avatar
400whp
Tune only
Old Dec 16, 2009 | 02:40 PM
n323er's Avatar
268whp
Stage II
2.7 pulley all colling mods and header dp cat back
John
Spec 3
Did i get it right
This post turned into
Old Dec 17, 2009 | 03:47 AM
BartSS's Avatar
I'm pretty sure that's the kit I'm gonna go with once the funds become available. Have you had any problems with it?
