warrenty
Old Sep 28, 2012 | 11:58 PM
tomj77's Avatar
warrenty
are axles covered under powertrain warrenty? my drivers side started clicking on and off when i downshift or shift gear or start moving for the second time iv had the car. replaced it once under warrenty, can i do it again
Old Sep 29, 2012 | 12:10 AM
Boostin15's Avatar
Yes they are I got mine replaced last month
Old Sep 29, 2012 | 12:12 AM
Boostin15's Avatar
I believe it doesn't matter how many times you replace a part under warranty
Old Sep 29, 2012 | 01:12 AM
tomj77's Avatar
just wanna make sure its under powertrain warrenty cause thats all i got left
Old Sep 29, 2012 | 02:12 AM
Macgyver2484's Avatar
CV shafts are covered under powertrain. There's also no e in warranty.
Old Sep 29, 2012 | 03:13 AM
007Balt's Avatar
thats great because I need to take Cobalt in also to get the right cv shaft replaced because it started knocking now lol
Old Sep 29, 2012 | 12:42 PM
tomj77's Avatar
lol thanks for that info
Old Sep 29, 2012 | 12:45 PM
FrossB's Avatar
Thread Killer
Is it still covered if you have mods?
Old Sep 29, 2012 | 02:07 PM
Boostin15's Avatar
No problem and yes it is still covered if you have mods. They have to prove that the mods you have done caused the problem with what's wrong
Old Sep 29, 2012 | 03:37 PM
SSlobalt's Avatar
Their only "proof" has to be a professional mechanic saying that the mods caused it. Ask me how I know.
Old Sep 30, 2012 | 02:54 AM
Boostin15's Avatar
Lol
Old Sep 30, 2012 | 11:31 AM
tomj77's Avatar
as long as u have nothing but the air piping they wont void it, if u got the downpipe or tune on there they will void it. or big turbo, or maf relocation. im sure they would with aftermarket clutch to if they could see it
Old Sep 30, 2012 | 09:37 PM
silverSS08's Avatar
What about lowering springs?
Old Oct 1, 2012 | 12:19 AM
tomj77's Avatar
oh idk bout that, good question
Old Oct 1, 2012 | 05:42 PM
silverSS08's Avatar
I'm having what I believe to be axle issues and I'm lowered on h&r springs. I'm under powertrain warranty but I think I should take the springs out before I bring it in. I get a bumpbumpbump on light acceleration and when I'm. Kind of half on half off the accelerator. Any ideas
Old Oct 1, 2012 | 05:52 PM
dcrep06's Avatar
i would take the springs off just to be safe. they might make a fuss about it, a friend of mine had a problem with it being covered since it had springs and aftermarket wheels -______- stupid ****.
Old Oct 1, 2012 | 07:23 PM
silverSS08's Avatar
I'm sure the lowering springs have something to do with the noise. I don't hav e rotated mounts. The car is stock otherwise(collecting parts to do it all at once). I could see them making a fuss about so I plan on taking them out. Is removing the springs a hard job? Ill have my cousin do it as long as it isn't too much of a pain
Old Oct 1, 2012 | 08:34 PM
dcrep06's Avatar
no its not, but he needs a spring compressor to put the stock ones back on. and the springs shouldnt cause any noise.....what kind of noise is it making?
Old Oct 1, 2012 | 10:13 PM
Cobalt_Daddy's Avatar
had my axle replaced last week. same clicking. should be an easy warranty claim. but i would remove your springs. they will no doubt blame them for the problem.. shouldbe able to change them more htan once if warranty is still good.
Old Oct 2, 2012 | 01:57 AM
FrossB's Avatar
Thread Killer
So this mod list probably wouldn't be allowed?? VVVV
Treadstone Stage 4 turbo kit with Precision 5557 JB turbo
All Treadstone bolt ons
Wiseco pistons
ZZP 4340 rods
ZZP 82# valve springs and retainers
New valve seals
Ported head and intake manifold
KY Stage 3 clutch with new TOB at time of install (appx 3000 miles on clutch)
KSport Kontrol coilovers
Moog sway bar end links
Hubs redrilled to 5x114.3
18x8 Inovit ST16 wheels
LSJ front brakes
OTTP Stage 2 Rotated mounts
Carbon Creations hood and G5 trunk
Hahn catback turned into a side exit
ZZP Triple pillar with:
-Red Interceptor Gauge
-Prosport Boost Gauge
-Prosport Oil Pressure Gauge
Tuned by chevycobaltss03
Old Oct 2, 2012 | 06:17 AM
dcrep06's Avatar
Wiseco pistons
ZZP 4340 rods
New valve seals
LSJ front brakes
oh noooo, thats no big deal man. i think you will still be covered under warranty.........lol
Old Oct 2, 2012 | 06:39 AM
FrossB's Avatar
Thread Killer
okay good lol
Old Oct 2, 2012 | 04:32 PM
silverSS08's Avatar
He has a spring compressor. I was saying I'm sure the lowering springs are causing the axles to make the noise. Not that the noise is coming from the springs. I would assume the axles might be binding from the drop in ride height. Its a bumpbumpbumpbump type of noise when I accelerate lightly. I wouldn't call it a clicking. Almost like I have a bent wheel but its not constant.
Old Oct 2, 2012 | 04:47 PM
07cobaltLScoupe's Avatar
to me it doesn't sound like axles. on H&R's you probably have some bump-steer but i don't believe they go low enough to kill axles, especially LNF axles. besides are your axles leaking? if they're shot you'd most likely be seeing some fluid leaking. are there any vibrations, other symptoms that you can tell? before your cousin swaps out springs i'd have him check the top strut mounts and make sure the control arms are all solid, could save you a lot of time and hassle if something is just loose or if it's not an axle problem...
Old Oct 2, 2012 | 05:20 PM
silverSS08's Avatar
We did the front brakes the other day and I asked him to look at the axles to see if he saw anything. He looked and didn't notice anything though it was just a quick glance. It may not be the axles. I have the springs on the stock struts and shocks. There are a lot of vibrations in this car and with how stiff the h&rs are its hard to tell with all the road noise. Last winter I noticed a grinding type of noise when making a sharp slow left turn. For example when turning left into a parking spot. so what are some things I should check out? You said the top strut mount and the control arms? What would I be looking for? Sorry to thread jack but anyone with any ideas let me know
