Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.0L LNF Performance Tech (https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/)
-   -   WB O2 sensor '08 SS/TC (https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/wb-o2-sensor-08-ss-tc-202265/)
Iam Broke Jan 22, 2010 07:40 PM
Part # and availability for the front WB O2 sensor?
Over 30k miles on mine and it looks like getting flaky from being cooked so much. I tried searching for a part # in the forum but no luck. Aftermarket or OEM? Price?
Thanks!
cmiller8006 Jan 22, 2010 07:43 PM
Would like to know as well. Thinking of changing before the race season do to the race gas. Kind of preventative
steddy2112 Jan 23, 2010 08:01 AM
12589380
Iam Broke Jan 23, 2010 08:21 AM
Thanks! Ordered it and a cupholder liner from a G5. Logs have been looking a little flaky lately and since I ran some leaded 110 blend last year I figure it's time.
Terminator2 Jan 23, 2010 12:32 PM
Mine crapped out so I am heading to the dealer on monday. It has been acting up for a few months now and it finally died completely and is showing a P2237 code that is not just coming and going away like it did in the past. I have never run any leaded gas or any race gas in my car. Me thinks they are getting too hot because GM placed them right on the turbo housing rather than on the DP.
Gimpster Jan 23, 2010 12:50 PM
Relocating mine a little further down the line is on the project list this spring.
I used to keep various Bosch based widebands (same sensor) in the o2 housing of my DSM's and they'd get cooked there too. Moved them to the downpipe and all was well.
Stamina Jan 23, 2010 01:04 PM
When an O2 hasn't popped a code yet, what do the logs look like when it starts getting sketchy?
Terminator2 Jan 23, 2010 01:09 PM
A/F bounces around a lot even on a bone stock car down the the airfilter. A/F spikes to 1.1 lambda and down to 0.89 lambda sometimes just while cruising. Misfires happen a lot even at idle. Rough idle especially when the car is first started even if the engine is already hot.
Just have to plug the old bung, extend the wiring for the sensor and weld in a new bung on the DP right before the cat if you have one still that is.
Stamina Jan 23, 2010 01:10 PM
Well crap... you just perfectly explained the problem I've been having. :lol:
Terminator2 Jan 23, 2010 01:14 PM
Mine has been acting up for about 4 months or so now and it was starting to annoy me when I can get everyone's elses cars tuned perfectly for intakes and such and mine would not dial in for me. Runs better now that it finally died because now the ECM is going off MAF, MAP and RPM not trying to correct for a lean or rich condition that is not really there.
Stamina Jan 23, 2010 01:18 PM
I saw this get answered before on another thread, but I couldn't tell what the final word was on it. How hard is that O2 on the turbo and the plug to get to?
Terminator2 Jan 23, 2010 01:30 PM
You will definately need at 02 sensor socket to make install easier. The sensor plugs into a connector right on the driver's side back corner of the valvecover. The only thing that makes it a PITA is all the AC lines are right there in the way.
Iam Broke Jan 23, 2010 02:18 PM
I had an intermittent P2237 last summer and disabled the code. Happened a month after going catless before the leaded 110 though. I thought it was the downstream one since I was catless, guess not.
Terminator2 Jan 23, 2010 02:24 PM
Bank 1 sensor 1 is the WB. Bank 1 sensor 2 you need to worry about at all.
BartSS Jan 23, 2010 08:22 PM
Looks like i might be getting a new 02 as well
Terminator2 Jan 24, 2010 10:05 AM
Yours crap out too?
steddy2112 Jan 24, 2010 10:11 AM
Mine came in yesterday. Ftw I'll change it out before I drive the car again
BYT*SS*TURBO Jan 25, 2010 10:15 AM
Short Extension + O2 socket worked best for me when I changed it. Reset the VCM after you change it ;)
Terminator2 Jan 25, 2010 10:16 AM
Maybe now my car will start running properly again LOL.
Stamina Jan 25, 2010 10:17 AM
Is the '09 WB02 the same part number?
I may pick one of these up today.
Terminator2 Jan 25, 2010 11:09 AM
Should be the exact same part number.
Stamina Jan 25, 2010 11:17 AM
Great
$129 and non-returnable.. ouch
Terminator2 Jan 25, 2010 11:22 AM
Originally Posted by Stamina (Post 4629603)
Great
CED has them for $58
BYT*SS*TURBO Jan 25, 2010 11:22 AM
GMPARTSDIRECT.com. I paid $60/each, I bought 2.
09 = 12589380
Stamina Jan 25, 2010 11:26 AM
09 = 12589380
I'll be doing that then. :lol:
There's a local outfit that's got these:
http://www.modernperformance.com/ueg...or-p-1691.html
Would that work? Since they're local, I could grab one today if that's the case. If it's different somehow, then I'll just order and wait.
