What does it take to trap 120-125mph?
I've seen Cmiller has gone 117. But in reality if i plan on selling my z28 i would like to trap above 120 to keep my interest in the cobalt without the Z28 in the garage.
It appears that a stock turbo wont get me there. But this is my DD so i dont want to really have the need to go huge on the turbo. I dont plan on taking the car to the track that often but i would like to run with a few buddies in their Fbodies/cobras when the need arises.
As soon as i take delivery of the new SS/TC i will swipe the check card for the following:
- Tune
- intake
- Catless DP
- Exhaust
- Short shifter
- Pedders
- wheels(unknown brand/style)
- upper/lower CP
- cooling mods
I have considered stealing most of my nitrous system for a small shot on the car. Although I'd rather not spray the car mostly because i only have 15lb bottles and i cant think of a great place to mount the bottle out of the way, unless i remove the spare. Also id like to keep the car in one piece for a while.
I am not willing to do zzp cams just yet although i will not deny how much they appeal to me. I <3 cams lol.
as i tell everyone. start with suspension and wheels/tires(slicks) and get your ET as low as you can before you start adding things to up the horsepower. you'll be surprised at how much it doesn't take.
Good luck getting the rest of the site to realize that the answer to running better times isn't always more power.
Most of my racing is not done on a track though
It sounds like you want the best of both worlds.
Stock like setup for street and the ability to tear it up at the track ...
The EFR would be your best bet. Closet to stock spool and more manageable in every day driving ...
You would probably have to do the cam as well as all the other stuff you want to do unless you want to run another rail and piggy back fuel controller. At least ZZP is saying that they are getting the fuel figured out although they are using the upgraded cam with a bigger lobe for the HPFP.
At least thats what I understand ..
I am in your same boat some what. I got back up vehicles for shop time so the DD thing isn't as necessary but it's an old Tahoe thats no fun and a beast to drive so the Balt still needs reliability.
In that sense I am just waiting for the BW EFR release , stock mani, BPV is on the same unit , intakes should bolt right on too. Unless the EFR sits lower.
0 traction and/or bicycle tires...
Only a Cobalt forum would aim for a trap speed and not E.T.
You may trap over 120, but you probably won't come close to cmiller's time. So in the end, you're still slow.
i wish people realized this kinda stuff. We wouldnt have all these bolted and tuned TC's trying to get out of the 14's still.
Then calling BS on the LSJ's that run low 13's with very little engine mods.
I have a couple goals. id love low 13's on street tires with 120+ traps
and id like mid 10's with the slicks.
If i need an ET there is a S60 and ET streets for that behind an LS1. Please understand the goals of the car before you begin talking to me about ET. Its about as ignorant as talking to me about braking capability when i am asking what it would take to reach 1.00g lateral grip. I am not confused on what i want, I have no intention of taking this car to the 1/4 mile aside from possibly a few runs one night to click off some times for testing.
bingo... 0 traction will get you the trap speeds you want. hence why i racn a damn 13.6 at 117 in my hatch. ZERO traction. **** i was still spinning through the traps when i did that.
Now i know the response you will come back with because you have read a few things on the internet about spinning increases trap speed. Where this is true is compared to say a full slick vs a drag radial. If you can still some what hook and go you will trap slightly higher due to the less rolling resistance on the drag radial compared to the slick.
I will also offer you this as i know you are still on the spinning = higher trap speed bandwagon. So you are telling me my 135 trap car will magically trap 145 if i just toss on some donuts on the rear? I would be spinning correct? But no, there is a loss in power that i cant put down and i cant create the same ET or the same MPH. Again, there is some truth to what you said but its not the end all be all.
I appreciate your response and input.
Just for clarification:
-Dont care about WHP
-Dont care about ET
-Care about reliable and street friendly
-Care about having some fun on the street with a few friends that trap 120+ in the 1/4.
-Care about Gas mileage over 25mpg
Thats pretty much it lol. I dont have retarded goals for this car and dont want to break records or anything else, i just want to have a lot of fun with a car that i enjoy.
Those who think spinning = higher mph crack me up. Never once in my lifetime has a spinning pass out trapped a decent non bogging launch in any of my 500+ timeslips. When you spin you are wasting time and ground to accelerate down the 1/4. Why do the fastest (et wise) stock cobalts have the highest mph?
Like I said, a simple ZZP kit on low boost will get you where you want to play with your friends from rolls. And you don't have to run enough boost to worry about internals going boom. You can if you want to smoke your friends once in a while and still be safe though.
swap the brembos to lsj brakes i think you can squeeze 16s on those. that way you can run slicks with more sidewall, air bag your rear and hang on tight, its cheap ( find an lsj guy i bet he would pay you to help you do the swap ) and you'll be alot quicker out of the hole. use that as a starting point and adjust HP needs from there
Also I won't ne getting rid of the brembos lol.
