what the hell is an EVAP cel??
Old Feb 24, 2009 | 12:03 PM
mrbroccoli08ss's Avatar
never had it before?? something to do with the gas cap i was told........
Old Feb 24, 2009 | 12:06 PM
ian48065's Avatar
it could be the gas cap not on tight enough or its evap emissions thing. honestly you can prolly clear it and it shouldn't come back on.
Old Feb 24, 2009 | 12:07 PM
krispy's Avatar
Basically gas tanks arn't allowed to vent fumes to atmosphere, so there is a small vaccum pulled from the tank through the engine. There are any number of things that can go wrong with the EVAP system. Loose gas cap is common, but there are other places for leaks and failures.
thats just it though ive cleared it twice in the past 6 months and it came on again yesterday. same damn code...and my DIC has said "check gas cap" before......
Old Feb 24, 2009 | 12:12 PM
NS06G5's Avatar
might be a crack in the plastic cap? They are cheap, pick up another one and give it a try.
Old Feb 24, 2009 | 12:13 PM
Terminator2's Avatar
Take your gas cap off and put it back on again until it clicks three times. If the code keeps coming back bring it to the dealer and have them inspect the Evap canister and lines for leaks.
Old Feb 24, 2009 | 12:17 PM
Mr_Slobalt's Avatar
80% of the time gas cap
20% of the time it's the EVAP vent valve
just from my experience lol
Old Feb 24, 2009 | 12:21 PM
so i should just take her into chevy and have them deal with it???
Old Feb 24, 2009 | 12:26 PM
anotherSSSCinPA's Avatar
I have the same issue. I noticed the CEL comes back after it rains, not sure its related though because it isnt 100%. I cleared it twice, last episode was probably a month ago and havent had it come back yet. I'll be taking it in next time it comes on.
Old Feb 24, 2009 | 12:28 PM
mkulrey13's Avatar
sounds like my cavalier...and i cant figure it out for the life of me... heard is big $$ to do a smoke test on it?
Old Feb 24, 2009 | 12:29 PM
Sunburst_SS's Avatar
There's a number of things it could be from a loose gas cap, leak in an EVAP line/seal, stuck vent valve, a purge solenoid that sticks open.
Old Feb 24, 2009 | 01:39 PM
That is what I would do. That is what they get paid to do. Let them figure it out.
Old Feb 24, 2009 | 01:45 PM
Firebirdhorn's Avatar
or it could be that some ******** cut some wires under your car like i had happen to mine. >
Old Feb 24, 2009 | 01:46 PM
Ferretts's Avatar
Happened to me... got the CEL and check gas cap... brought it to the dealer and they said it was the canister... Ordered the part waiting on it so they can replace it.. no money spent
Old Feb 24, 2009 | 01:49 PM
krispy's Avatar
Werd, you paid for the warranty on your car when you bought it, you might as well take advantage of it.
Old Feb 24, 2009 | 01:51 PM
Psykostevo's Avatar
The EVAP cel has come up on a few LNFs. It does not appear to be a big issue. Some have had it caused by cracking or breaking on the intake where the braided line connects. Other times it has been the EVAP canister. Seen it on 2-3 cars.
Old Feb 24, 2009 | 02:38 PM
yeah i dropped mine off about an hour ago...no word back yet
Old Feb 24, 2009 | 07:39 PM
tomj77's Avatar
did u fill up recently? if u did its ur gas cap, take it off and put it back on and clear the code and u should be good.
Old Feb 24, 2009 | 07:43 PM
BLAZIN07SS's Avatar
I'm too JDM for you
when you fill up, do you still put gas after it clicks to top it off? i have seen so many cars screw up there charcoal canister and fill it up with gas by topping it off, then throw an EVAP code cause they have a bad canister. just throwing that out there as another probable cause.
Old Feb 24, 2009 | 10:35 PM
Wow ironically, my CEL just came back today. WTF Dealer time.
Old Feb 24, 2009 | 11:13 PM
got my car back about 3 hrs after i dropped it off...replaced the purge valve??? said there was a bad solenoid...never heard of this... have you?
Old Feb 24, 2009 | 11:16 PM
BLAZIN07SS's Avatar
I'm too JDM for you
yes, this is the valve that opens to send hydrocarbon fumes to be burnt in your engine at cruising speeds. if it wasnt opening, that would have explained your cel
Old Feb 24, 2009 | 11:28 PM
this is the 2nd time in a month its happened..was it bad to wait that long?? i honestly thought it was the gas cap due to the warning i got on the dic earlier saying "check gas cap"....the cel came on almost at the same time...weird
Old Feb 25, 2009 | 08:44 AM
turbo_chevy_cobalt's Avatar
i had my purge value replaced twice and it still was coming up even got new gas cap. there a few different codes for the evap. i had the high purge flow code. the evap richs the mixture when it sees it can. i one of the ones that found the crack on the intake.
Old Feb 25, 2009 | 06:38 PM
t5665y's Avatar
had it come on on my car and it turned out to be a purge valve. dealer took care of it in a bout a half hour in and out
